1982 rear hatch won’t open
Old Oct 15, 2011 | 05:35 PM
atikovi's Avatar
atikovi
Default 1982 rear hatch won’t open
When I pull the release I can hear the latches release and I can raise the left side of the glass a quarter inch but the right side won’t move. The top front of the glass is a quarter inch back from the weather strip so I think the pins that engage the latch are jamming into the latches by the force of the lift supports. Is there some trick to open jammed latches? Can the latches be loosened from the body?
Old Oct 15, 2011 | 10:49 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Have someone pull and hold the latch while you go to the back of the car. Since you can get one side to release, push in the other side towards the front of the car. You may be able to move it enough to release. Chances are good that your hinges have bent slightly. I went through this with my old CE. Good luck.
Old Oct 16, 2011 | 12:51 AM
vettebuyer6369's Avatar
vettebuyer6369
It is a CE, right?
Old Oct 16, 2011 | 08:23 AM
atikovi's Avatar
atikovi
Yes CE. Nobody here to help. Can I unbolt the glass from the right rear point?
Old Oct 16, 2011 | 09:07 AM
jlsru's Avatar
jlsru
Cruise-In V Veteran
I had a CE that the hatch was out of adjustment.I removed the interior
halo to get to the adjusting bolts. Loosened the bolts and readjusted the glass and it worked fine.
Old Oct 16, 2011 | 09:23 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
The hinges stretch over time letting the glass move to the rear, the striker pins than become stuck in the striker assy. once open you will need to readjust hinges and possibly the strikers.
Make sure you have some help as the glass is heavy and a bit awkward to handle and hard to find if broken.
Good Luck
Old Oct 16, 2011 | 12:00 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
We see this quite often as the collector cars age. The design of the hinge holding the glass is made from soft cast metal and over time they open up (Widen). A good way to know for sure if this is your problem is to look at the rear window moldings and see if the striker bolt is hitting the molding. It usually leaves a hefty mark on there. When it does this the glass moves backward on the car and the rear of the glass actually rises upward
What this causes is an issue with the fitment of the rear hatch weatherstrip and an issue with the striker pins locking in place.
The solution is to find a set of the repro hinges which are quite expensive. I've tinkered with the idea of making these over the past few months but have not done so.
The solution for getting your rear window open is listed above by way of having someone inside the car pull the handle while you push on the rear glass. This might release it but in some cases it will not.
The other solution again mentioned above is to take the hinge lose inside the car. This will usually take the tension off the glass.
You can try to readjust the hinge to get a better fit but nothing will solve the issue with it opening up besides being replaced.
Old Oct 16, 2011 | 01:36 PM
atikovi's Avatar
atikovi
I unbolted the right hinge, but again the lift support is pressing the glass rearward. I don't want to force it with the hinge unbolted because I can imagine the lift support letting go and forcing one side of the glass up or even breaking it. I'll see if I can reach the glass mounting point at the rear.
Old Oct 16, 2011 | 02:03 PM
0Willcox Corvette
Former Vendor
What about taking the corner molding off.. then remove the retainer from the shock and remove it there. That should remove the tension in a more controlled manner.
Old Oct 16, 2011 | 02:07 PM
0Willcox Corvette
Former Vendor
Old Oct 16, 2011 | 02:42 PM
atikovi's Avatar
atikovi
OK I got it open. Used a mini tie-down ratchet strap thing to pull the glass away from the latch and then pull up on the glass. Got the left side out first, then the right. Had to position the strap at 4-5 places and work with the glass.
I see right off that the right pin isn't centered:
like the left one on that oval:
Is that just bolted through the glass or is there some adhesive as well?
Also I see how the hinges are distorted. Can I just take them out and pound them flat again?
Old Oct 16, 2011 | 02:57 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Good work so far Yes the steel portion or hinge looks to be bent quite a bit. I would take them apart and do my best to straighten them out, after your done you may need to fab up some spacers to add back under the plate. The adjustment just takes a lot of trial and error, be sure your shocks are unhooked and you remove the latching pins while making adjustments.
Here is a link to some info, that may help.
http://www.corvetteaddiction.com/82c....php?f=1&t=427
Old Oct 16, 2011 | 07:53 PM
atikovi's Avatar
atikovi
Well that didn't work at all. I must have misunderstood the term hinge as used in this application. I thought that stamped metal piece which is all bent up in my picture is the hinge everyone was referring to when in fact I see it's the curved black arm made of solid metal that bends (distorts?). I bolted everything back together after straightening those brackets and can just about stick a pencil between the glass and the seal at the front. ARRGH! OK, so what repro hinges are available for this car? And I’m getting ahead of myself but I’ll also need lift supports. Can someone tell if these are the originals? If so, would it be better to get them sealed and recharged from an originality standpoint?
Old Oct 16, 2011 | 08:12 PM
0Willcox Corvette
Former Vendor
I guess I need to find a good original hinge and make these... If I can find one I can make both sides from steel on a Hurco.
I have a link for the repro's somewhere at my office.. maybe someone will chime in before tomorrow..
Willcox
Old Oct 17, 2011 | 04:16 PM
atikovi's Avatar
atikovi
I got everything back out and have the window upside down on my couch with penetrating oil on the allen screw that holds the hinges to the glass. Plan is to try and bend them back into the correct shape if I can get the hinges off the glass.
Old Oct 17, 2011 | 04:18 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
These are the ones I was referring to, You will need to add shims between them & the halo to bring the glass back down. It looks as if someone just bend them instead of adding the right amount.
http://www.thecubestudio.com/picture...gePunchWeb.jpg
As to the black cast part they can be bent back, but they are a pot metal and will break. It is U shaped and the distance between the two fastening points is what gets stretched wider allowing the glass to move lower in the opening.
I found 2 used ones in case I broke one, than used a vice and slowly squeezed them back in shape (as in put a very small amount of pressure let sit about 30 minuets then squeezed a little more) In all I only went 1/4 inch.
Read this http://www.thecubestudio.com/Collect...structions.htm
Old Oct 30, 2011 | 08:57 PM
pigag2's Avatar
pigag2
I had the same problem on my CE. Brought new replacement hinges from WWW.thecubestudio.com and they worked really well. Not cheap at over $300.00 but I can now open my hatch. Your lift supports are the original ones. There is a shop in Edmonton, Alta, Canada where you can get them reloaded. I have yet to get mine reloaded. I'll get the name and let you know.
To 1982 rear hatch won’t open
Old Oct 30, 2011 | 09:44 PM
atikovi's Avatar
atikovi
I found a set of those hinges in a box of parts with the car. I'll install them soon. That place wanted like $70 each to recharge the struts plus shipping roundtrip. Bought a pair of Strongarm struts for $55 delivered.
Old Nov 7, 2011 | 02:42 PM
Texas Stinger's Avatar
Texas Stinger
Originally Posted by Vettebuyer5869
It is a CE, right?
I would hope so, otherwise the previous owner would have to do some explaining as to why there is a button that pops up one side of the rear glass.
Old Nov 7, 2011 | 04:46 PM
atikovi's Avatar
atikovi
Yes CE. Got everything back together and it works great. Pull the release and the hatch goes up all by itself.
