gel coat 1976
gel coat 1976
what is the color the factory used. i find an off white color when i get to last paint color scraping with razor blade. three blue same color.
than what was sprayed on the body before paint a primer for sealing the fiber glass if so could it be a white color. lots of scraping and lots of blades
Received 1,470 Likes
Cruise-In II Veteran
The factory used gray and red primer. I'm guessing the "off white" you are finding is factory primer.
Three color coats and gray primer sounds factory correct.
