Crate Motor or Not?
I also found some metal shaving, along with small pieces of metal. I am thinking a main or rod bearing has failed. I made planned to get a crate motor and replace this one. Here’s where I cannot make up my mind. I heard if I replace this engine with something different than the stock the value of the car will go down.
I am not showing this car, it is my to and fro work 2-3 days a week. If I install a crate motor and a 5 speed transmission, how close will I get to the market prize for this 1972 LT1 with original motor in it if I decide to sell down the road?
I planned on keeping the original motor and re-build it using some of the latest parts available: EFI kit and aluminum heads, and valve train to accommodate the EFI. Hoping to extract 400-500 out of it, for now I need to have the car running just so I can drive it when want.
During the re-built phase any suggestion on which:
EFI kit
cylinder heads
cam
lifters and rocker arms to get to accommodate the EFI?
Is it worth the effort to send out the original engine and have a reputable company to re-build it? My apologies for the all the question. Thanks in advance.
MAYBE I would stroke it and put a mild cam in. And as a bonus you won't have the origional engine to trip over !
My vote is for crate.
I can find something just as extreme:
GMPP LS376/515 with a 10.7 to 1 compression ratio
Add carburetor and a MSD ignition controller.
I see pricing starting at $7100.
I don't know how the motor mounts would work out.
Or a first generation small block:
GMPP ZZ4 with 10 to 1 compression ratio, forged crankshaft, and distributor
About $4,000
look at year one crate p/n CT350PC1
make guaranteed 400 hp&tq w/ real dyno sheet, pump gas, roller cam, NOW w/massaged iron DART vortec heads, about 9.7:1 scr, pump gas, good warranty, but even better reputation, LESS than $3000 USD.
do a search: lotsa happy CT350PC1 users over several years.
Engine Specifications:
* Horsepower: 400+
* Torque: 400+ ft/lbs
* Compression ratio: 9.7:1
* Dyno-tested: Yes, includes 8" balancer & 14" flexplate
* Dyno sheet: Included with engine's output
* Vacuum produced: 12hg @ 800RPM
* Recommended fuel: 92 octane
* Max recommended RPM- 5800
* Block: Seasoned 4-bolt iron
* Crankshaft: OE cast iron
* Pistons: Hypereutectic
* Connecting rods: Powdered metal
* Camshaft- Hydraulic roller with YearOne proprietary specifcations
* Rocker arms: Stamped steel 1.6:1 ratio
* Cylinder heads: Ported Dart Iron Vortec
* Valves: Stainless steel 2.02 int/1.60 exh
* Valve springs: Heavy duty
* Bore x Stroke: 4.04" x 3.48"
* Intake manifold: Dual-plane aluminum
* Oil pan, timing cover, valve covers included
* Engine fasteners: High tensile strength
* Warranty: 12 mth/12,000 mi
http://www.yearone.com/serverfiles/f...50pc1&SM=1&SC=
only downside I see: bores already +0.040" leaving little room for any subsequent rebore/overhaul ... but for another $3K or so, replace it ... priced a typical overhaul lately?
bag the OE motor, crate for driver
* Horsepower: 400+
How's the stock SB hood clearance with this?
It's advertised & pictured with professional products "crosswind" intake p/n 52028 (china clone of eb airgap). May fit LT1 hood but may require drop base air cleaner.
Or, perhaps, order motor with shorter pro products "cyclone" intake p/n 52007 (china clone of eb performer). But, expect a loss of about ten to fifteen at MAX hp&tq ... while low to mid rpm numbers might improve ... maybe not.
* Horsepower: 400+
thats why I chose the following- with ALL NEW PARTS and a 5 year-50k mile warranty by GM..It was a bit more expensive, but it was also a turn key motor.
check it out:
http://paceperformance.com/i-5146077...ck-finish.html
Bob is a smart man!
Les
