You'll need the power steering center link (or relay rod) and the pitman arm, to do the conversion.
With power steering, the ball stud needed to attach the center link to the pitman arm, is part of the power steering control valve. With manual steering, the ball stud is installed in the end of the center link itself. The manual steering pitman arm is curved differently, to properly meet the manual steering ball stud.
Everything else from your PS system (steering box, knuckles, etc.) can be reused.
When eliminating the power steering, the slave cylinder is not needed, and can be removed.
If you do switch to manual steering, save the PS components to resell. The old PS components (slave cylinder, control valve, pump, center link, pitman arm and pulley) are worth a few hundred dollars to the rebuilders, or someone looking to convert to PS.
Many vendors offer rebuilt center links. You can also get good used ones from any vendor that deals in used parts. One shouldn't be that hard to find.
There are 2 different manual steering center links. The 63-68 one has 5 holes in it, while 69 and later ones, have 3 holes. Either one should work, it's just that the 63-68's were designed for use with a steering damper, that Chevrolet eliminated in 69.
I don't think so, and apparently, neither did Chevrolet.
While Chevrolet did include it on all lower horsepower 63-68 Corvettes. It was not used on 63-65 solid lifter engines (it wouldn't clear the larger oil pan those engines used) or on 65-68 big blocks. Then in 69, they did away with it altogether.
Curious what the difference is in the center link and pitman arms.
The difference between them is below, from my previous post.
What happens if only the hydraulic dampner is removed
It is not a "damper" on the power steering system. It's a slave cylinder that provides assist to the steering system.
You can remove it, but if you don't change the pitman arm and center link, the effect will be the same as just removing the belt from the pump. You will have manual steering, but I think that the effort needed to steer it will be much higher than if you use a non power pitman arm and center link.
I pulled all of the power-steering stuff from the motor and the slave cylinder. I haven't had a chance to properly finish the project by swapping out the two items above but it really isn't that hard to drive. My girlfriend drives it just fine like that.
Just my two cents...wanted to let you know you could pull that junk hanging on the front of your motor and your car would still be plenty drivable.
The linkage geometry between the manual and power pitman arms and the relay rod with or without the tapered hole for the power steering assist cylinder is almost exactly the same.
So the manual steering effort should be the same -- EXCEPT for the fact that on a power steering system you are pushing power steering fluid in and out of the assist cylinder with every motion of the relay rod/steering wheel. So if the pump was removed from the system (i.e. remove the belt) now the fluid just circulates in the system with the motion of the assist cylinder. You will have additional steering effort caused by manually moving the power steering fluid.
Just as a point of information. If you were to install plugs in the assist cylinder ports rather than hoses, you would effectively "lock up" your steering system since you would be trying to move incompressible fluid that has no place to go. You could cobble together a "U-tube" to connect both ports of the assist cylinder. Now your assist cylinder would be acting as a damper.
Jim
That's were I was going. So if you remove the pump and the slave cylinder there would be no fluid or anything in the system that has to do with the power steering and the car would still drive.
What i'm gathering is that effort may change a little bit, but will work.
When I look at the two pitman arms and the two center links the difference doesn't seem substantial enough to make a huge difference.
Almost switched over to manual steering but found out about this Borgeson Steering Box.Bolts up in the stock location,no more leaky ram and control valve.Looks factory and steering is quick and precise.
[IMG][/IMG][IMG][/IMG][IMG][/IMG] One of my best upgrades!
