Differential Fluid Question
Old Oct 21, 2011 | 08:53 PM
ziller's Avatar
ziller
7th Gear
Default Differential Fluid Question
Ziller pumped out all the differential fluid from the 1979 and replaced it with Royal Purple - Max Gear High - Performance Gear Oil (75w-90). The bottle sez that it is limited slip.
Question: Is this good enough? Or is the GM special formula and additive required?
Thanks in advance.
ziller
Old Oct 22, 2011 | 01:08 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Ziller..
I'm not a huge fan of Royal Purple.. but yes.. you'll need the additive. 1052358 is the old GM number...
I'm not sure of why you drained the rear but if the clutches were sticking and you have what we call "waddle" when turning corners then I would put two bottles in.. drive it in a parking lot doing figure 8's.. then drive it some more on straights... Drain and refill with standard old gear lube and 1 bottle of additive. If the clutches were sticking this should clear it up.. if not.. then you might consider pulling the rear and replacing the clutches.
IMHO,
Willcox
Old Oct 26, 2011 | 10:18 AM
BTGRN75's Avatar
BTGRN75
St. Jude Donor '11
Originally Posted by Willcox Corvette
Ziller..
IMHO,
Willcox
IYO -how often would you recommend rear end (with posi) fluid changes?
Old Dec 17, 2011 | 07:27 PM
papafrancisco's Avatar
papafrancisco
Default Where is plug to change diff oil on '79 AUTOMATIC?
help please
Old Dec 17, 2011 | 11:56 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I've run Royal Purple with no additives for years and it works great in posi's. Never seen anything but good stuff out of them so far.
JIM
Old Dec 18, 2011 | 01:25 AM
jimo's Avatar
jimo
[QUOTE=Willcox Corvette;1579022998]Ziller..
IMHO,
I added 2 bottles of additive when I had the same problem and it did the trick!!
Old Dec 18, 2011 | 03:26 AM
hunt4cleanair's Avatar
hunt4cleanair
Originally Posted by papafrancisco
Where is plug to change diff oil on '79 AUTOMATIC? help please
Is there two questions there?
You ask about the differential drain plug but refer to a 79 automatic...no difference between auto and manual transmission regarding changing the differential fluid on a 79. I see the C5 logo so you may be assuming the transmission/differential is one unit as with C5 but this is not the case for C3.
So having said all that, the differential plug is on the passenger side above rear leaf spring. Should be a GM red tag that says "USE LIMITED SLIP DIFF. LUBRICANT ONLY" To drain the fluid you have to use a fluid pump or pull the cover which you do not want to do unless absolutely necessary...like you have a differential leak and need to replace the gasket
Old Dec 18, 2011 | 10:27 AM
mds3013's Avatar
mds3013
Drian plug here. mike...
Old Dec 18, 2011 | 10:49 AM
Paul L's Avatar
Paul L
Just a tip. Use an 8-point (not 6- or 12-) 5/8" socket to get that plug out.
To Differential Fluid Question
