HID headlight conversion
Old Nov 19, 2011 | 02:21 AM
eagle275's Avatar
eagle275
Originally Posted by vette427-sbc
The fiber optic plugs into the factory headlight plug and "looks" into the back of the lamp through a clear spot in the glass. So if you retain a factory style plug and bulbs that have the clear spot, then yes your fiber optics will still work
So if I build some new harnesses, I have to have the factory type headlight plug? I am reading up on this and asking questions because I never really tinkered with the lights in all these years, but now I want to do one of Dan Stern's upgrades, with a new heavier gauge harness, yet keep the optics working,etc. Thanks for the info. If I buy new optics parts? Where do I get factory plugs,etc?
Old Feb 5, 2014 | 05:25 AM
bebezote's Avatar
bebezote
Originally Posted by bluegtp
Yup, I have true hid's on mine. No projectors though. I had to run new thicker wires and relays. It's was a pain but I was also dealing with 30 year old wiring with poor grounds. 2 outer lamps are hi/lo and middle 2 are strictly hi's. Replaced original sealed beams with hella housings. I'm running the 55w hids in the 4500k color.
Search, there are some that have done projector hids and some that just upgraded to some non sealed beam lamps with regular halogens.
Hi BlueGTP...i know this thread is a little old... but... arent the outer lights always just low beam...then when you switch to hi beam... you get all 4 on.???
So.. i bought 2 kits like the below off ebay... and once installed..i was hoping to get the 2 outer ones on..during low beam...and then all 4 on with hi beam..
the only switch i want to make is to upgrade from 35w ballasts and bulbs to 55w's in all low and high...
am i wrong here on how the outer and inner bulbs on an 82 c3 work??
http://www.ebay.com/itm/380693271336...84.m1439.l2649
Old Feb 5, 2014 | 10:28 AM
Rotonda's Avatar
Rotonda
You need to run new wire from your relays to the headlamps and new ground wires to the frame. Its not too much... snaking the wires through the looms and up to the bulbs is the hardest part (ie: not very difficult).
Good relays (I used 2 Hella 40Amps) are $9 on summit racing. I went to autozone and got 3 rolls of their 12gauge wire. I think they are little over 10 ft each roll. You might need more depending on where you put the relays. Then you will need two 10 or 12gauge inline fuses, and a piece of 8gauge wire to go from the alternator stud to the inline fuses. Add a few more $$ if you dont have little things like spade connectors for the relays, heatshrink tubing, solder, etc... Shouldnt be over $50
Heres my setup... Could use some cleaning up, but it works well for now. I have my fan relays here to. All incoming power is fed through a 4gauge wire from the alternator, junctioned at the horn relay, and fed to the relays through 10gauge inline fuses
An easy way of creating this bank of relays is to use ARC p/n 1440, which has 4 relays plus integrated ATO fuses for each relay. I used this when I put euro headlights in my XJ6 and it worked and was easy. I got the part from JEG'S.
Old Feb 5, 2014 | 10:53 AM
Brians1's Avatar
Brians1
I just started my Headlight conversion, and will be creating a new thread on the Minimal modifications I need to do, but here is a sneak peak of the lights I chose and the mods...Again I will start a new thread to document my progress (don't want to take over this thread...just offering up another headlight option )
Lights chosen (from e-bay - 135 bucks)
These are H4 Xenon's at 60w, blue Halo LED ring
