Help rpm tachometer
Old Nov 4, 2011 | 09:19 PM
willis5719@aol.com's Avatar
willis5719@aol.com
2nd Gear
Default Help rpm tachometer
Can someone tell me what is going on with this gauge? A friend owns a 1979 L-82. The gauge just stop working. He bought a new circuit board last may not any good at electronics he called me to help with the repair.I watched the video from Willcox and installed it. before I installed the unit in the dash we put 12V to it it seemed to work so we put it in the car plugged it in connected the battery started the engine the needle went backwards. He bought the board from Corvette America if that helps.I did check the fuse it is good.
