Oil pressure question
Old Nov 7, 2011 | 08:34 PM
RacrX's Avatar
RacrX
St. Jude Donor '08
Default Oil pressure question
What should it be (specifically on a '73 350 190hp) and what would be a possible cause of low pressure (35psi)?
Old Nov 7, 2011 | 08:40 PM
couperdecar's Avatar
couperdecar
I thought if we had 10lbs per 1000 rpms we were good. What rpms are you reading 35lbs at?
Old Nov 7, 2011 | 09:22 PM
Mike Ward's Avatar
Mike Ward
35 lbs is perfectly normal.
Old Nov 7, 2011 | 09:29 PM
RacrX's Avatar
RacrX
St. Jude Donor '08
Oh. Ok then, never mind...got some bad info.
There may be more dumb questions coming stay tuned.
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
35 is normal after the engine is warm
Old Nov 7, 2011 | 09:59 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
There are several factors as to how much oil pressure one has with his engine. 1) Rear main bearing clearance. 2) oil weight 3) oil pump (hi flow or stock). 4) Engine condition.
But.. 35lbs is perfectly normal and would not in my mind even come close to being called low.
Put this worry to rest, you don't have any issue at 35 lbs.
Willcox
Old Nov 8, 2011 | 07:23 AM
rdroe's Avatar
rdroe
DC Area Events Coordinator
Mine starts about 40 cold then settles between 35 & 40. I was used to our Lotus running at 50psi but it's a different animal.
Old Nov 8, 2011 | 05:35 PM
LancePearson's Avatar
LancePearson
Default same here
My 76 L48 is as above.
Lance P.
Old Nov 8, 2011 | 09:20 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
I wish I had 35 lbs!
Old Nov 9, 2011 | 07:10 PM
John A F's Avatar
John A F
My 79 L-82 after warm up give 20psi at idle and about 33-35 psi at 50-60 mph. I use 10W-40 oil.
Old Nov 9, 2011 | 08:06 PM
Paul L's Avatar
Paul L
Yes, and even the Owner's Manual says so. The Corvette version, not the Lotus.
To Oil pressure question
