window felt removal
Old Nov 11, 2011 | 11:55 AM
todds74's Avatar
todds74
Default window felt removal
I need some help im trying to remove the window felt weather strip from my doors and cant get to the screws because door glass is in the way . Is there a way to get the door glass to go down any more they are power woindows and the car is a 1977. Thanks
Old Nov 11, 2011 | 12:51 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
There is a stop on the bottom of the track that you can adjust downwards to give you a little more clearance. Just loosen the bolt and the stop will slide down.
Old Nov 11, 2011 | 01:24 PM
Roco71's Avatar
Roco71
If I understand it correctly you can remove the anti-rattle bumpers and push the glass closer to the door panel to gain more room.
Old Nov 11, 2011 | 01:48 PM
todds74's Avatar
todds74
Default Thanks
Thanks guys I will try both of those.
Old Nov 11, 2011 | 02:44 PM
Kevin68's Avatar
Kevin68
You'll need to remove the door panel for this. And the angle of the screwdriver is less than optimal, but it is doable (on a 68 anyway).
If you loosen the window stop, you might want to mark where it goes back to.
To window felt removal
