This explains why my reverse SUCKS!
Uploaded with ImageShack.us
What is this about? Somebody try to throw it onto reverse at 50 MPH???
Im going to need a reverse gear, a idler, and the bearing support on the front end....anybody have any cheap sources?
To avoid doing that to the new gears always put it into a syncro'd gear before going into reverse. The syncros will stop all the spinning gears and it will slip into reverse without a grind.
If you have had the gridning going into reverse and it's a little difficult to push it into 1st at a standstill you really want to look for causes of a dragging clutch.
BTW, if you hadn't seen them, those gears would have gone another 50,000 miles.
Steve
Unless you really enjoyed the experience of removing that trans (removing it was the easy part
) don't put it back together without going through it completely and regardless of how they appear, replace the syncro rings. The o'haul kit gives you the bearings, gaskets, synchros and seals. If you are buying a used frt bearing retainer check it closely for wear at the point the release bearing slides. A ridge will cause it to hang up.Steve g
Both are a resource for good info.
In either case it would be sheer folly to not look at the clutch at this point.
It sounds like you are judging the condition of the synchros by the condition of the teeth. That's not what wears out on them. The inner circumference is an inverse cone that that rides on a cone on the adjacent gear. As you start to put it in gear pressure is applied on the synchro and the cone acts as a brake. The circumference of the cone on the synchro, because it is a braking surface, wears over time. Eventually the synchro ring's outer circumference bottoms out on the adjacent gear before the synchro can apply enough braking on the cone surfaces to stop the spinning gears. Then you start to get period grinding on shifts. You will have had accelerated wear because your trans was running in a bath of grinding compound with all those gear bits in there. It took out your ext housing bushing and yoke already.
It sounds like you may be missing the most essential piece in your tool collection, the factory service manual. Of all the money you could spend on that car that would be the most cost effective. You really need to know what you're looking for and proper information on assembly procedures. You need to be looking at end play and thrust washer conditions on your counter gear, counter shaft wear ...
Steve g
However, the worst thing you can do for your trans is not tear it apart completely, especially in light of what you've found so far. Items that are about to fail or are worn beyond serviceabvle limits will fail and damage other very expensive parts. Not uncommon to have a failed mainshaft, worn bores in the case where the counter shaft fits, broken pieces going through and breaking a tooth on the cluster, etc...
Lots of things work fine until they don't anymore. You are in a position now to prevent some very costly damage down the road. Doing your inspection based on budget constrainsts may is counterproductive.
Chilton manuals are fine for some very general things, but lack specifics on more indepth repairs. You will not find trans internal specs and procedures in most unless it is a transmission specific edition and even those are not great. Years ago that was all we had and you made do. but after working with factory manuals you would throw rocks at your old Chiltons. A factory service manual gives you everything you need to properly maintain and repair that car.
Steve g
Now honestly, anything can be taken apart. How easy is it to put back together? Based on your knowledge, would it save me the headache to take the case to a shop for a rebuild or is this something that goes together as easily as it comes apart? Any special tools? I see the manual calls for several kinds of snap ring pliers...and Im going to need a puller to get that danm speedo drive off....
Check end play in the counter gear with a feeler gauge before you disassemble it and compare to spec. If it's out of spec check the case and the thrust surface on the gears when you have it apart. If all okay new thrust washers will clean that up. Remove the shaft from the cluster and let the cluster drop into the bottom of the case. You can now pull the input shaft and bearing out. For reassembly you go to Home depot and buy a piece of 7/8" or 1" (depending on your counter shaft pin size) and cut it exactly to the length of the cluster gear. This is one of the tools you need for reassembly. The others are the snap ring pliers and possibly a bearing splitter and press if you have to replace the pressed on bearings.
Once the counter shaft is out check it for wear where the bearings run. Look for pitting or galling on it as well. Check the bearing surface inside the cluster as well. Thoroughly wash everything with solvent.
The main shaft you inspect the parts as you take them off the shaft once you've removed the snap rings and speedo gear. You don't need the special speedo gear removal tool. You use the same kind of bearing splitter you use on any other bearings and set it in the press.
Do you need to have someone else do it? I don't know. I find them easy, but I've been a Journeymen for almost 40 years and have done dozens. On the scale of difficulty, I would say not very. Some investment/access to tools and equipment is required. Do know that if you take it in they will replace everything in sight. It's called insurance on their part. They're expected to warranty it and they wouldn't dream of reusing bearings.
Steve g
I know all my gears are good, I know the synchros appear to be good from the exterior. Is there a 'basic' rebuild kit I should be looking for? If Im going to have it torn apart, shouldnt I just replace the bngs? (I dont have a press, but I can find one)
What are the most common mistakes I need to avoid?
John
