problem!!!!
Old Nov 12, 2011 | 07:00 PM
pipelu524@yahoo.com's Avatar
pipelu524@yahoo.com
Default problem!!!!
today i took my 81 to see about new mufflers.for a more agressive sound,anyway the car was lowered down off the lift..and now when i hit the brakes it pulls drasticly to the right...is it just a coincedence or just a caliper hanging up???cause the car wasnt driven much at all..just bought it 3 weeks ago..... just baffled!!!! thanks
Old Nov 12, 2011 | 08:05 PM
milo30's Avatar
milo30
What kind of lift did they use? One with ramps to drive on or arms to swing under the frame?
Old Nov 13, 2011 | 12:20 AM
pipelu524@yahoo.com
arms under frame
Old Nov 13, 2011 | 12:42 AM
milo30's Avatar
milo30
Maybe it is just coincidence but time to pull the wheel and check everything out.
Old Nov 13, 2011 | 01:09 AM
pipelu524@yahoo.com
tomorrow morning!!
Old Nov 13, 2011 | 11:08 AM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
"Pulling" to the right indicates the right caliper is braking more than the left caliper. Something is going on in the left side brake system. Often the rubber flex brake line just before the caliper will break down internally restricting flow. When you pull your calipers down, be sure to inspect the rubber hose internals.Remove them to look thru. If they have never been changed, now is the time.
It MAY also be that the lift damaged part of the braking system . A visual inspection is in order.
Old Nov 13, 2011 | 11:15 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
the brake lines are above or beside the frame rails
Old Nov 13, 2011 | 11:35 AM
Priya's Avatar
Priya
There might be contamination on the brake pad that's pulling harder.
Old Nov 13, 2011 | 11:55 AM
joewill's Avatar
joewill
check for oil dampness on your rotor indicating a leak.
check which rotor is hotter, the cooler one is the one not braking...
Old Nov 13, 2011 | 06:39 PM
milo30's Avatar
milo30
Thirty years ago they were but who knows what might have been messed with over the years and replaced incorrectly.
Old Nov 13, 2011 | 07:02 PM
pipelu524@yahoo.com
that was the problem!!! thank u for the walk through!!!!!!getting two hoses tomorrow
To problem!!!!
