1972 rear lights????
Old Nov 12, 2011 | 07:32 PM
Sully1882's Avatar
Sully1882
Default 1972 rear lights????
Do all four tail lights illuminate at once of do the two outer ones do brake and light and the two inner ones only light up when car is in reverse?
Thanks in advance,
Sully
Old Nov 12, 2011 | 08:04 PM
Tom73's Avatar
Tom73
Inner ones are reverse only.
Old Nov 13, 2011 | 02:08 AM
avner's Avatar
avner
Only in 68 the 4 tail light work together and the reveres light is in different place (under the bumpers), see this link, how FM change later model to work as 68.
http://forums.corvetteforum.com/c3-g...ake-lamps.html
Avner
Old Nov 13, 2011 | 10:58 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Sully1882
Do all four tail lights illuminate at once...
No disrespect, but since this is an otherwise obvious question, I am wondering whether your actual intent concerns a tail light conversion kit. If all four light up on any 69-82, someone has installed the kit, usually with bubble lenses.
To 1972 rear lights????
