Hood problems closing hood
Old Nov 18, 2011 | 02:13 PM
buffed1978's Avatar
buffed1978
Default Hood problems closing hood
As long as i have had my 78 vette over 15 years i have always had to drop my hood to get it to lock. I have never been able to just lower it down slowly and get it to lock..is this with every 78 or is their something i can do to make lock easy without slaming the hood down.
Old Nov 18, 2011 | 02:54 PM
Hardway's Avatar
Hardway
I have to do the same on my '81. All of the gaps are good around the hood so I do not believe it is an issue of it not being on the car correctly. I would be interested in hearing other owner's experiences too.
Old Nov 18, 2011 | 03:10 PM
Ret.Horsecop13's Avatar
Ret.Horsecop13
St. Jude Donor '11-'12-'13-'14
Mine is a pain also. I put it down gently and push each side down till they lock. Just the nature of the beast I guess.
Old Nov 18, 2011 | 03:25 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Lower it to about six inches, then let it drop. Works on my '80.
Old Nov 18, 2011 | 04:38 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
From the movie Mr Mom: you're doing it wrong
six or so inches high then drop it. if you do it the way your doing it now it will start to crack the glass in your hood.Ive never gotten my 77 or 75 hood to shut correct without doing the drop method ,If something works I stick with it!!!!!!!!!
Watch you hood bend when you just push one side down at a time.
Old Nov 18, 2011 | 04:49 PM
TexasTechDad's Avatar
TexasTechDad
make sure to push the hood release forward after opening the hood, it's a C3 thang!
Old Nov 18, 2011 | 09:57 PM
EmNash's Avatar
EmNash
Old Nov 19, 2011 | 10:40 AM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
yeah... why is that??? i never understood why there wasnt some return spring so you dont have to push it back in.
Old Nov 19, 2011 | 11:26 AM
TexasTechDad
Don't look at me! I just know what works!
Old Nov 19, 2011 | 04:20 PM
Ret.Horsecop13
I would think you would crack the glass easier dropping the hood than pushing a side at a time. But thats why I'm here to learn something new everyday!
Old Nov 19, 2011 | 04:31 PM
milo30's Avatar
milo30
I think the glass is strong enough that a small drop doesn't effect it. Lowering it then pushing, flexes the hood and makes it more susceptible to damage. The only bad thing about dropping it is when you are working on the car and forget to remove something that will block the hood and you drop it on that.
It's been that way even on the C4 and C5's I've had. ave to drop them to get them to catch
Old Nov 19, 2011 | 05:57 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
I have to do the same thing.....works every time now..
But as far has the 8 in drop I stopped doing this cause after I just spent a ton of money having the car painted and the underside of my hood done I have found crackes in the supports that go from side to side (fender to fender) where the holes are in the support...
Old Nov 19, 2011 | 07:00 PM
BFI6603's Avatar
BFI6603
Let me agree with the majority....my 82 needs the 6" drop too.
Old Nov 19, 2011 | 07:17 PM
C3-PO's Avatar
C3-PO
Default most important!
Absolutely a must ... my '80 after day one, 31 years ago ... it works every time. the hood latches will not catch if the release is not pushed completely foward after unlatching. gently lower the hood onto the latches, then pull up and drop from about 8"-10" (18cm - 25cm) and it will not hurt the hood at all. no need to lube the latches either. no misses, cracks, warps ever. just thud and go.
Old Aug 11, 2020 | 09:29 PM
HDRIDER957's Avatar
HDRIDER957
Good news. My bonding exercise with my ‘68 is over! The hood is open! With the camera i was able to clearly see where i needed to land the ratchet wrench and I got the last bolt lose and the hood popped open.
Thank you to all that helped! It’s very much appreciated!
Old Aug 12, 2020 | 06:25 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Good news, unfortunately it got posted in the wrong thread. I think you went to far down and got into the "related thread" dark realm......happens alot
To Hood problems closing hood
