77 again
Old Nov 20, 2011 | 10:25 AM
Acesone's Avatar
Acesone
Default 77 again
Need help as to where to connect vacuum line which is supposed to connect to manifold fitting then to a plastic filter w/ 2 lines coming off of . Thank You Again- Hope someday I can help someone else!!
Rich
Old Nov 20, 2011 | 10:39 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
For headlight doors? You should have a fitting on the intake manifold runner between the carb and the distributor. Hose, filter (white plastic), then check valve (metal).
Old Nov 20, 2011 | 10:53 AM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Old Dec 1, 2011 | 11:46 AM
Acesone's Avatar
Acesone
tnx for help!! Rich
To 77 again
