I have 71 350/270 and would like to know the preferred removal of the stock hood? Remove the hood plus mount'g brackets or remove hood from the mount'g brackets. I want very little trouble realigning. thanks Mike
Unless there are specific reasons to, hinges should not be messed with. Scribe around the hinge plate on the hood and remove hood. Replace using scribe lines as guide. Minor adjustments from this point will almost certainly be needed for hood to hit latch points correctly.
Mark the placement of the hinges on the hood. Scribe, tape, paint, crayon...whatever you want to use. I used a plain old nothin' fancy #2 pencil. Remove the hood from the hinges leaving the hinges on the fender skirts.
Come install time, match your marks to the hinges.
