fuse box
Old Nov 26, 2011 | 12:22 AM
rzkas's Avatar
rzkas
Default fuse box
hi? i have a 82 corvette and i need a fuse panel fuse indicator diagram or fuse lable and fuse number and what it controls. diagram and picture will be great.
thanks
Old Nov 26, 2011 | 11:25 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The 82 owner's manual probably shows a picture of the fuse panel and will list the correct fuses. The AIM page is a bit busy.
Old Nov 29, 2011 | 02:00 AM
rzkas's Avatar
rzkas
more info pls. do you anyone has a better and clear pic . thanks for the above pic but it hard to read the info on it.
Old Nov 29, 2011 | 07:48 AM
MN80Vette's Avatar
MN80Vette
The diagram you are looking for is in every manual you can buy for an '82 Corvette. Those manuals all have copyrights. There are more than a hundred currently for sale on eBay. There are some in CD form too.
There are several manuals to choose from. The GM shop manual is most comprehensive, the assembly instruction manual (AIM) has the most and biggest pictures (but no text instructions), owners manuals are the cheapest but don't say much about repairs, and the Haynes and Chilton repair manuals are somewhere between the shop manual and the owners manual. Personally, I like the shop manual best, but I own all of the above.
If you are going to do any work on your '82, you should own at least one of these manuals.
Old Nov 29, 2011 | 09:59 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by rzkas
more info pls. do you anyone has a better and clear pic...
Check your owner's manual. If you do not have an owner's manual, order a reprint.
To fuse box
