Help w/ continuous beeping
Old Nov 26, 2011 | 11:56 AM
yoandy10's Avatar
yoandy10
Default Help w/ continuous beeping
I realized yesterday that when I remove the key from the ignition, the beeping sound coming from the fuse box speaker continues to beep and the gauges lights remain on. Even after I shut the doors the beeping and gauge lights remain on. What could be the problem? I am running out of ideas and need another mind at work.
Old Nov 26, 2011 | 12:58 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
You will get more answers if you let everyone know the particulars about the car such as year, model, etc. Might want to fill out your profile. It helps!
Old Nov 27, 2011 | 11:48 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Turn the headlight **** and see if you dash lights go out. I think your beep is reminding you the interior lights might be on.
Owner's manual should explain the beep.
Old Nov 27, 2011 | 12:17 PM
yoandy10's Avatar
yoandy10
I tried this and did not work. Would it be this?, even though the rest of the lights go out. Only the gauge lights remain on. I'll try again and see if it works.
Old Nov 27, 2011 | 03:04 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
Sounds like the headlight switch may be failing. There are a couple of threads about how to check it.
To Help w/ continuous beeping
