starter question
Old Nov 28, 2011 | 08:27 PM
tbloomer's Avatar
tbloomer
1st Gear
Default starter question
I have a 1982 corvette which I believe has an issue with the starter. The battery is fully charged but when I attempt to start, I will turn the key all the way and it just clicks, doesn't try to turn over, just makes his clicking sound. I do this 4 or 5 times and eventually it starts. I would like to fix this myself but do not know too much about fixing cars. Can anyone give me some advice?
Old Nov 28, 2011 | 10:30 PM
fanmanbd's Avatar
fanmanbd
The clicking is the solenoid which means it is working but the starter is not. Try starting with the head lights on. If they don't dim it's the starter.
Old Nov 28, 2011 | 10:37 PM
my 76 ray's Avatar
my 76 ray
It could also be as simple as dirty connections at the battery or a poor ground.
I will send a PM.
Old Nov 28, 2011 | 10:40 PM
iokepakai's Avatar
iokepakai
Had the same issue,but it was an el-cheapo mini starter.It worked for a month then started doing what yours is doing,click,click,click then it would start.Got worse and worse,had me chasing bad wiring,weak battery which none of that was the problem.Replaced the starter with a GM mini starter problem gone all good! Lesson learned buy quality parts!! Aloha's
To starter question
