Restoration?
Old Nov 29, 2011 | 12:04 AM
Max03's Avatar
Max03
Navigator
Default Restoration?
What do you guys think about this one?
1978 L-82
25th Anniversary
4 Speed Manual
14k Original Miles
What should i tackle first it hasn't been ran for 5+ years?
Old Nov 29, 2011 | 04:07 AM
hunt4cleanair's Avatar
hunt4cleanair
Ouch...is that mold on the engine compartment? Very bad rust on the master cylinder suggests brakes need to be rebuilt all the way around.
change all fluids including gas. Check chassis for fluid leaks.
Old Nov 29, 2011 | 04:58 AM
Ralphbf's Avatar
Ralphbf
Try this:
http://forums.corvetteforum.com/c3-t...down-time.html
Ralph
Old Nov 29, 2011 | 07:30 AM
Max03's Avatar
Max03
Navigator
Thanks guys and yeah im affraid so the master cylinder is around 79.99
Old Nov 29, 2011 | 11:03 AM
Hardway's Avatar
Hardway
Don't be scared. Is this a car you currently own or just bought? The MC is no different than on any other GM car. As others have said, complete fluid change, swap the MC, test all functions of the car, wash it, and take it for a drive.
Old Nov 29, 2011 | 11:06 AM
Max03's Avatar
Max03
Navigator
Currently own and have owned for awhile its just been sitting in the garage. And thanks can you tell me a proper cost saving way to wash the engine bay?
Old Nov 29, 2011 | 01:54 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Max03
...What should i tackle first it hasn't been ran for 5+ years?...
Starting it.
Good luck.
Old Nov 29, 2011 | 02:09 PM
Sunstroked's Avatar
Sunstroked
Quickest way is to search for a place that steam cleans engine compartments. Not pressure wash. I have had a few cars done in the past, steam removes the grime pretty well. Last time I had one steam cleaned was when I bought my 92 vette, almost 6 yrs ago, cost about $50. It was worth it. To keep it looking presentable i take a dedicated California duster to the engine bay. I hate dirty engines.
Old Nov 29, 2011 | 05:16 PM
Max03's Avatar
Max03
Navigator
Thanks ill look around!
Old Nov 29, 2011 | 05:54 PM
brent319's Avatar
brent319
C3 of Year Winner (appearance mods) 2019
A little work and that could be a really nice ride! Good luck and keep us posted.
Old Nov 29, 2011 | 07:53 PM
Max03's Avatar
Max03
Navigator
Thanks and will do
Old Nov 29, 2011 | 09:06 PM
mikem350's Avatar
mikem350
Go through the FUEL SYSTEM...from tank to the carb!!!
That is going to be your biggest problem...flush out all the old gas and crud
Especially with the ethanol in new gas...
Old Nov 29, 2011 | 10:12 PM
Max03's Avatar
Max03
Navigator
Thanks for the tips
Old Nov 29, 2011 | 11:02 PM
1974ta's Avatar
1974ta
Default Engine cleaning
My suggestion for the engine compartment is to carefully disassemble as much as you can and then start from the top down and clean by hand with dish detergent and low pressure rinsing.
I would also have the original MC rebuilt and sleeved. Save the original hardware and bag and tag in case you want to have the hardware restored at some point.
All fluids should be changed. Complete tune up and save ALL original parts regardless of condition.
Turn the engine over by hand. Have the carb professionally rekitted and cleaned.
Drain and drop the gas tank and scrub it clean. Flush all gas lines.
This is just for starters.
Looks like a really fun project
I would love to have a 14k mile original to start with like you do.
Bill
Old Nov 29, 2011 | 11:20 PM
Max03's Avatar
Max03
Navigator
Bill
Thank you! And yeah 14k has a lot of fun to come
To Restoration?
