how to simulate engine vacuum?
Old Nov 29, 2011 | 07:06 PM
shamby's Avatar
shamby
Default how to simulate engine vacuum?
Is there a way to simulate engine vacuum without the engine in the car? I’ve got a hot rod heating and air system that runs on vacuum and I’d like to have it installed and working so I can get my interior back in order while the motor is out, but I need some type of vacuum to operate the servos. Any ideas on how to test them?
Old Nov 29, 2011 | 08:30 PM
corvetteload's Avatar
corvetteload
vacuum pump?!?!?!?!
http://www.harborfreight.com/25-cfm-...ump-98076.html
Old Nov 29, 2011 | 08:33 PM
Steve2147's Avatar
Steve2147
There are small hand held pumps that will give you adequate vacuum, but they move a small amount of air. They're great for testing indivicual vacuum motors (diaphrams) but are not great if you wanted to put the entire system under vacuum. Your hand will fall off before you've drawn down a vacuum in a larger chamber.
To test the entire sysem, say where you wanted to replicate the single vacuum source that the engine provides you'd need an electric vacuum pump. I've made myself an adapter so that I can use the one I use for evacuating AC systems. Works very well, but of course you still don't have the cfm that the engine has, which is only an issue if you have a leak in your vacuum system.
Steve g
I think Mighty vac is a very popular handheld one.
Old Nov 29, 2011 | 08:39 PM
myk7's Avatar
myk7
You can also run a vac line from another car for testing
Old Nov 29, 2011 | 08:40 PM
shamby's Avatar
shamby
thanks for the post. I was not sure if the vacuum pump would do the same thing. I hate to spend the 100 bucks on something for a one time use. I'll check out the handheld ones.
Old Nov 29, 2011 | 08:43 PM
shamby's Avatar
shamby
Love this forum. I have know idea on why I did not think of that. The jeep is right next to the car and I have a boat load of vacuum line.
Old Nov 29, 2011 | 09:20 PM
Aussie79's Avatar
Aussie79
I have in the past used my vacuum cleaner, just take off the main vac line from manifold and duct tape it to the inlet of your cleaner, turn it on and my headlights operated no problem, heater vents etc all worked. No good for looking for a leak but if all you want to do is test installed devcies its ideal.
You may have to explain to the wife why the hose is covered in grease, mine just rolled her eyes and said "figures".
Dennis.
Old Nov 29, 2011 | 09:30 PM
shamby's Avatar
shamby
I thought about using my small shop vac, but could you have to much vacuum.
Old Nov 29, 2011 | 10:02 PM
Dave J's Avatar
Dave J
Try this thread........
http://forums.corvetteforum.com/c3-g...t-sharing.html
Old Nov 30, 2011 | 12:40 PM
pauldana's Avatar
pauldana
i use a vaccume pump from harber freight, works GREAT! 100$ p:-)
Old Nov 30, 2011 | 12:44 PM
Mike Ward's Avatar
Mike Ward
Simple as that.
Old Nov 30, 2011 | 02:52 PM
pauldana's Avatar
pauldana
The problem with running it from another car is the noise... a lot of time if you run a pump (also far enough away) you can hear where the vacuum leaks are coming from, this is very valuble as there are so many things running on vacuum in our cars, old hoses running back and forth from everywhere, and the leaks are 50% of the problem ... you can not do this with a loud enging running next to you.... Also, fumes... unless both cars outside... i like working inside...
To how to simulate engine vacuum?
