Another "won't start" thread
Old Dec 15, 2011 | 02:29 PM
Billem's Avatar
Billem
Default Another "won't start" thread
Am redoing the interior and got it just about torn apart (1974, 4speed). A friend stopped by last evening and wanted to hear it run. Clutch in, key on, interior and dash lights fine, no start. Everything dims slightly when I go to "start" but the starter doesn't even growl. When I hooked up jumper cables, lights were a little brighter but still no start. I am a newbee in the 'vette deal, so maybe I'm overlooking something? All suggestions will be considered/tried. Thanks and Merry Christmas, Bill
Old Dec 15, 2011 | 04:23 PM
Billem's Avatar
Billem
Just after I posted, I thought I'd better check the battery. 7 volts. That may have something to do with the problem. Possibly I didn't get a good connection when I jumped it. I'll post again when the thing is charged. Merry Christmas and Happy New Year! Bill
Old Dec 15, 2011 | 06:36 PM
Stoge's Avatar
Stoge
7 Volts! Thats one dead battery.
I bet it fires right up after being charged.
Old Dec 15, 2011 | 09:42 PM
ctroadster's Avatar
ctroadster
I'll bet you had the doors open for hours with battery still connected, been there done that
Old Dec 15, 2011 | 09:55 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
bet you never even thought about that, lol. battery should be disconnected for safety not to mention running it down
Old Dec 16, 2011 | 07:39 PM
Billem's Avatar
Billem
Charged up the battery and hooked it up this a.m. Same problem. I have no idea why I did this: when I flipped the tilt wheel down, fired right up. Tried it again with wheel in upright position, nothing. Wheel down: started perfectly. Same thing a couple more times - same results.
Help! Thanks and Merry Christmas, Bill
Old Dec 16, 2011 | 08:08 PM
atikovi's Avatar
atikovi
Are the battery terminals clean and tight? Use a wire brush on the battery and cables until they shine.
Old Dec 16, 2011 | 08:13 PM
driddick's Avatar
driddick
Connection in the steering column? Sounds like a short
Old Dec 16, 2011 | 09:56 PM
ctroadster's Avatar
ctroadster
sounds like the wires are being stretched and good connection lost when the wheel is up. not sure if the harness has a plug that might be the culpret
Old Dec 17, 2011 | 06:34 AM
Paul Workman's Avatar
Paul Workman
If the tilt wheel seem to play a role (being either up or down making a difference), coupled with the lights dimming with the key in the "start" position, I know I would be looking for a short in the steering column harness.
I'd start looking at the spot where the tilt wheel flexes. Take a hard look at the wiring right there first.
P.
Old Feb 29, 2012 | 11:21 AM
jesse10886's Avatar
jesse10886
Did you ever find the culprit?
Old Feb 29, 2012 | 12:00 PM
Billem's Avatar
Billem
Haven't found a for sure reason. The wiring looks good under the dash and steering column area, but I'm thinking it may have had someting to do with the seat belt warning system on the passenger side. It's too long a story to go into right now, but I have the system disconnected and it hasn't missed a start since. As long as it starts, that project will just have to take a number and wait in line. Have a great day, B
To Another "won't start" thread
