Tank help!!!
Old Dec 22, 2011 | 02:22 PM
great68's Avatar
great68
Default Tank help!!!
How do you get the rubbler boot off of the tank spout? I need to see if there is any paper work in there? I noticed the screws that take the lid off do I remove them first?
Old Dec 22, 2011 | 02:26 PM
MelWff's Avatar
MelWff
yes remove the screws holding on the lid/ring and the boot just slides off the neck of the tank
Old Dec 22, 2011 | 02:56 PM
garage-ghost's Avatar
garage-ghost
It's a tight fit, some rubber lube around the tank neck will help.
Old Dec 23, 2011 | 09:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Push the edge down a bit and you might be able to see whether your tank sticker is there without removing the collar. You'll need a good flashlight or shop light.
Old Dec 23, 2011 | 01:28 PM
great68's Avatar
great68
Folded the rubber down on both sides and all I could see was the tank straps. I checked side to side, should I check top to bottom and could the sticker have slid down?
To Tank help!!!
