Diff ratio 1968 427
Old Dec 26, 2011 | 07:28 AM
kazzrich's Avatar
kazzrich
Default Diff ratio 1968 427
I have a 68 427 with Muncie 4 speed box.
It revs out far too quick and has a limited top speed, I go rapidly through the gears. I can take off in 2nd and go stright to fourth, obvious copious torque with the 427 rollar cam rebuilt motor (orig No.)
How can I determine my diff ratio and change it to more wind out in each gear. It has enough hp and torque but I want it to push me back into the seat rather than having to rpaidly change gears
Old Dec 26, 2011 | 09:50 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Differentials are coded on the bottom with the original gear set. Your problem might be whether a previous owner swapped out the gears.
http://www.mcjackscorvettes.com/facts/68.htm
Old Dec 26, 2011 | 01:50 PM
BOSTONCAMARO's Avatar
BOSTONCAMARO
You can get a pretty good estimate but jacking the car up safely and put it in nuetral, mark the driveshaft, rotate wheel, get an idea of how many rotations.
This can be a somewhat accurate way, get a ballpark of the ratio.
See this link for description of what to do:
http://www.livestrong.com/article/22...ing-one-wheel/
Old Dec 27, 2011 | 08:59 AM
kazzrich's Avatar
kazzrich
Default Thanks
Thanks for the responses and links. I couldnt make out any markings under the diff but had limited time this evening. I will jack it up tomorrow and count revolutions to get the ratio.
I suspect it will be highly geared so what is the opinion on a suitable ratio to give me more wind out in each gear and plenty of push back in the seat.
Also, can anyone recommend a brand and place to buy new ratios
To Diff ratio 1968 427
