Considering a '78
Old Dec 26, 2011 | 10:44 PM
diamond78's Avatar
diamond78
Default Considering a '78
So I'm thinking about picking up a '78 - but I know nothing about the C3s...what should I look for and/or ask about?
Old Dec 27, 2011 | 09:28 AM
moosie982's Avatar
moosie982
Ru$t, in the birdcage and frame, any other problems are pretty easy to fix compared to these two item$, clean title, Good luck in your search.
Peace,,, moosie
Old Dec 27, 2011 | 09:54 AM
CrusinZ06's Avatar
CrusinZ06
Yes i agree with moosie, there is lot's of information on here in regard's what to look for when shopping for a C3.
As mention rust, read the information on here about the bird cage, where to look and investigate these problem area's, will be beneficial to you in your search for a sound C3.
Good luck
Old Dec 27, 2011 | 02:37 PM
80Baby's Avatar
80Baby
A '78? Besides the frame and birdcage issues let's take it one step further... worn suspension bushings and rear spring spacers. I finished tearing down an '80 and rust and bushings were my big issues.
Old Dec 27, 2011 | 02:42 PM
milo30's Avatar
milo30
If you don't know what the bird cage is then run a search and there is tons of info on it. Do your research on here before buying. A '78 is a relatively inexpensive C3 and is a good car to get into the hobby with just make sure that you don't over pay. Buy one in the best condition you can afford vs. a fixer upper and you will come out ahead.
'78 and later weren't know for their power. Decide whether you want a stock car or one that has had an engine replacement/upgrade. All the little things will add up and get expensive so be sure you get the type of car that you want to end up with or it can become a real money pit.
There are lot's of them out there to choose from so don't get hung up on just one.
Old Dec 27, 2011 | 04:12 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
See if you can find a copy of this; it may be out of print, but copies are out there. Covers all C3 model years.:
Old Dec 27, 2011 | 06:55 PM
couperdecar's Avatar
couperdecar
What should you look for ? Look for a '79. WAY nicer styling !
To Considering a '78
