Cigarette lighter removal
Old Dec 27, 2011 | 10:48 PM
ATOWNCORVETTES's Avatar
ATOWNCORVETTES
1st Gear
Default Cigarette lighter removal
How do I remove the entire cigarette lighter mechanism as well as the ashtray cover from a 1980 Corvette?
Old Dec 27, 2011 | 11:14 PM
mds3013's Avatar
mds3013
From the '77 AIM. Assembly Instruction Manual. Your '80 should be close to the same. The outer sleeve unscrews from the inner core. mike...
Old Dec 28, 2011 | 07:06 AM
Rotonda's Avatar
Rotonda
1) Remove the side panels from both sides of the transmission tunnel. This is held on by several screws.
2) Remove the shifter ****
3) Remove the 6 screws securing the console shifter plate. There are 2 in the front , holding the the plate onto the small gauges center stack plate; 2 on either side towards the center of the console center plate; and two in the rear, securing it to the armrest/e-brake.
4) gently begin to lift the plate, disconnecting wires/plugs as you go.
5) slide the plate up, off over the shift ****.
6) the ashtray lid is held on by two plastic rivets. These rivets have a hollow center with filled by a plastic rod. You can salvage these rivets by working this plastic pin out (when replacing, simply squeeze the pin back into the rivet), or purchase replacements from most vendors. NOTE: Using small bolts or other metallic substitutes tends to either restrict the easy opening of the door or give you a small rattle.
7) removal of lighter is accomplished per previous post.
8) reverse above to reassemble.
remove the ashtray lid by disconnecting the spring
entire console shifter plate
To Cigarette lighter removal
