Dash cap install/pad removal question
Old Dec 28, 2011 | 02:08 PM
johnmb's Avatar
johnmb
Default Dash cap install/pad removal question
Got a new dash cap for Christmas and I'm guessing that it's probably best if I remove my present pad for cleaning, etc.
A couple questions:
1) Do you recommend removing the existing pad (cracked ) in order to properly prep it for installation of the cap?
2) What all needs to be removed to take out the existing pad? I've searched here and there's lots of threads on removing left and right pads (lower) but for some reason I can't find one about removing JUST the top one.
Thanks ! Hope Santa was good to you all!
John
Old Dec 28, 2011 | 03:30 PM
mmtr's Avatar
mmtr
Please let me know what you end up doing. This is on my project list as soon as I finish up my carpet project. Taking much longer than expected.
Old Dec 28, 2011 | 03:39 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
IF you intend to remove the existing pad to install the cap (that would be my choice, but it's not my cap), you will probably have to remove the passenger's side dash pad in order to get to the mounting bracket and bolt for the upper pad.
Do you have the AIM? It shows the bracket and bolt.
Old Dec 28, 2011 | 05:31 PM
Mashman's Avatar
Mashman
Wilcox has some good documentation - http://willcoxcorvette.com/instructi...ith_pics_2.pdf
Old Dec 28, 2011 | 09:02 PM
sweeet76's Avatar
sweeet76
Willcox info is good. It's an easy project as far as corvette projects go. I would use a different glue like contact cement or something of that nature.
To Dash cap install/pad removal question
