L88 Hood update
Old Jan 5, 2012 | 10:20 PM
81pilot's Avatar
81pilot
A couple more......
The white lines are NOT crooked cuts, it is the light shining through the glass where I sanded the gel coat off.
From the top front:
From the top rear looking at the extension, it is really looking great and flowing good, now to sand, glue on, float out with glass and start floating with thin Bondo.
Old Jan 5, 2012 | 10:47 PM
Clubby99's Avatar
Clubby99
Nice job. Keep us updated.
Old Jan 6, 2012 | 09:27 AM
BOSTONCAMARO's Avatar
BOSTONCAMARO
Clubby...nice cabinets and flooring, very similar to my house......the hoods in this post are also looking good
Old Jan 6, 2012 | 10:28 PM
Clubby99's Avatar
Clubby99
Ask me how popular I am for storing car parts in 2 out of 5 bedrooms?
We should convince 81Pilot to join us in the "OBX Sidepipe Club."
I enjoy reading your car thread. Keep it up!
Old Jan 6, 2012 | 10:52 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I still hear about the one time that I stored my air cleaner in the living room IN A BOX UNDER THE COUCH! To hear it now, the entire drive train was in the middle of the floor spewing oil.
Old Jan 6, 2012 | 11:17 PM
Clubby99's Avatar
Clubby99
Tell me about it...
I "volunteered" to vacuum the living room so no one would notice the rocker panel covers under the sofa.
Old Jan 10, 2012 | 11:18 AM
81pilot's Avatar
81pilot
OK.....OBX Sidepipes?? When the car is painted the theme will scream for sidepipes........but maybe black....
Old Jan 11, 2012 | 10:46 AM
81pilot's Avatar
81pilot
Which Body filler did you use to float out the edges of the scoop?
I am leaning toward the Evercoat Rage Gold, easy sanding and is good for glass and SMC glass.
Old Jan 11, 2012 | 01:12 PM
Roco71's Avatar
Roco71
That's what I used on mine.
Old Jan 12, 2012 | 10:05 AM
81pilot's Avatar
81pilot
It was NOT cheap!! Sheeesh!
Old Jan 12, 2012 | 03:16 PM
Roco71's Avatar
Roco71
The stuff is great to work with really flows and levels great... plus no pin holes.
Old Jan 12, 2012 | 03:47 PM
69 Chevy's Avatar
69 Chevy
Float out? Sounds like power troweling a concrete floor.
Old Jan 13, 2012 | 07:59 PM
  #33
81pilot's Avatar
81pilot
Yep thats what is sounds like.
Old Jan 13, 2012 | 08:11 PM
  #34
81pilot's Avatar
81pilot
Here is some more progress. Tomorrow it will be all leveled out with Body filler and ready for primer, on the home stretch!!
Old Jan 13, 2012 | 08:50 PM
  #35
Clubby99's Avatar
Clubby99
I used Evercoat Extreme. I agree it is expensive. Floating on? During application, I noticed little difference with much cheaper Bondo. The big improvement is almost no pin-holes. I recommend a thin layer over any exposed fiberglass. Fiberglass is filled with small pin-holes that are hard to see but show up after primer. You can just sand the gelcoat. What are you going to do with the raw fiberglass under the hood?
Did you ever test fit the hood on your car? Do you have any pics? How does that extension look compared to other long L-88 hoods?
My car is a '72 that had a long hood and no wiper door. Bubba-d!
I'm reinstalling the wiper door assembly and grill (very hard to fit it) and my new short L-88 hood. The wiper door parts (including all the small parts) cost about $1,500. I really want a wiper door.
The hood had been delayed because I've spent two weekends getting the wiper door to fit right. Finished that today. It matters because the wiper door fit determines how much fiberglass to remove in the back to get the gap perfect.
Old Jan 13, 2012 | 09:14 PM
  #36
81pilot's Avatar
81pilot
I test fit it before this point, I am going to refit it and shim and get it as good as I can and then use a little filler to fix a couple of low spots.
I am not sure what my plan is on the under side. I can just use the filler to finish the underside. I want it to look good as well. Any suggestions? Lengthwise it is now a tad over 53 inches long and looks right, I am glad I lengthened it. I will shoot a pic tomorrow with it on the car.
Your spot on with the wiper door, on the cars that came with the short hood need it, you might as well do it right, sometimes it costs more, but the end result will be nice.
Old Jan 13, 2012 | 09:26 PM
  #37
Clubby99's Avatar
Clubby99
I'm thinking about a thin coat of filler and sanding. Wondering how much weight that would add.
Sanding alone would likely make the fiberglass too thin. What if we brushed on more resin then sanded it smooth?
To L88 Hood update
Old Jan 20, 2012 | 11:40 AM
  #38
81pilot's Avatar
81pilot
Default Body Filler definition
filler definition: A high dollar substance that you use too much of and then proceed to sand most of it back off, then you repeat as many times as neccessary.
I always use too much to begin with.
I am done with the Rage filler on the top, I am in the process of using 2 part X glaze to get it perfect (as I can) then I will shoot the 2K primer and block sand some more, whew, my arms get tired, but it is looking good. I will upload a few pics tonight, it is coming together though. I think on the bottom, I will just sand the glass and put a layer of X glaze on it, I not concerned as much on the back about it being perfectly flat, it is aweful close now. Then just prime and shoot black on the back. Decided against a color change on the car this year, going to paint to match the hood to the car, then paint the center of the scoop with the same Dark Bronze as the bottom of the car, should be nice looking and good for now.
Old Jan 22, 2012 | 05:49 PM
  #39
81pilot's Avatar
81pilot
Here is where I am at. I took the weekend off from it, will hit it after work this week, should have it fitted this week and shoot primer next weekend.
Old Feb 22, 2012 | 10:02 AM
  #40
81pilot's Avatar
81pilot
OK here is the latest of the finished underside. I am about to prime the top and it is going very well. I have had back issues and had to curtail some of the work, but I am back at it.
