Rpo code help
Old Jan 10, 2012 | 02:44 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Default Rpo code help
Hello everyone,
from my tank sticker I'm trying to find my rear gear ratio.
What ratio was 02G81CA?
I know it was a posi traction (G81)
Not sure what the CA equates to in a ratio.
I just can't read the type after posi traction ......
I know when its warmer I can climb underneath and
get the 2 letter code.
I also thought the tank sticker had it listed.
Any one with same or that knows can you let me know?
Thanks,
Marshal
Old Jan 10, 2012 | 04:25 AM
hunt4cleanair's Avatar
hunt4cleanair
Originally Posted by marshal135
Hello everyone,
Yes...G81 is the RPO for positraction. The gear would have been an additional RPO and should be listed on your build sheet. I believe it would have been listed above the G81 RPO
CA is the exception control letter (ECL) and provided the factory worker with additional part selection for a particular RPO...as I recall. CA was probably called out for a particular gear ratio but you still need the gear RPO
AXLE
You must be in Alaska!
Old Jan 11, 2012 | 01:39 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
On the same line, out to the right of the 02G81CA code, your should see POSITRACTION AXLE and the ratio listed. Might be difficult to read, but it should be there.
It's on this one, but a little hard to read. 3.08:1
Old Jan 11, 2012 | 07:14 PM
marshal135's Avatar
marshal135
Mike
Thanks that is what I was hoping someone here could verify.
I figured it for 3.08:1 because at 2000 rpms I'm at 50 mph in 4th gear on an M20 trans.
Life just got good
Marshal
To Rpo code help
