Coil Spring on E-Brake cable
Old Jan 11, 2012 | 08:23 PM
Mooser's Avatar
Mooser
Default Coil Spring on E-Brake cable
I've got one spring that's broken on the end of the E-brake Cable (out on the trailing arm where it hooks to the e-brake lever)
The cable is fine, looks like maybe it (the spring) got caught or something and is broken in 2 places near the middle.
I've managed to get the old one off by basically un-screwing it (arms and everything is off the car so the cable is on the bench.
Looked through my selection of stuff and only found some newer ones that have a plastic/rubber sleeve over them.
Don't want to replace the cable if I can just buy a spring. Anyone seen anyone selling them?
Mooser
Old Jan 13, 2012 | 05:43 AM
69small block's Avatar
69small block
Default spring
new ones are available call Mike Dyer he can get you one
