Tie rod question
Old Jan 15, 2012 | 05:50 PM
Xterrable's Avatar
Xterrable
Default Tie rod question
Just want to confirm that BOTH outer tie rods and standard Right Hand thread, making the inners left Hand Thread. Thus making the direction to rotate the tubes to shorten them different.
Is that correct?
Just double checking because it seems that either mine were on backwards OR I was shipped the wrong part..
I think RockAuto has them listed wrong, because if this is so, then both outers should be the same part No. But they have Front Right Inner and Front Left Outer listed as the same part No..
Old Jan 15, 2012 | 11:26 PM
Jim Shea's Avatar
Jim Shea
By convention both outer tie rods should have left hand threads. The inner tie rods should be right hand threads.
The original Corvette adjuster tubes from around 1964 through the late 1970s had a groove machined on the outside near the LH threaded end of the tube. This would have been for internal identification at the Chevrolet-Buffalo linkage plant. Since the linkage came fully assembled to the Corvette assembly plant, they relied on the Buffalo workers to have assembled the linkage correctly. The assembly plant worker in St. Louis depended upon the fact that when he rotated the adjuster tubes to set front wheel toe, the rods had to always extend or retract when the tubes were rotated in the same direction.
The following drawing shows the RH and LH relationship.
BTW, since the Corvette inner and outer tie rods were the same except for the direction of threads, they will function perfectly well with both RH threads to the outside and both LH threads on the inside. Your alignment man will most likely be able to cope with the fact that your adjustments using the adjuster tubes will be backwards from the production versions.
Jim
Old Jan 15, 2012 | 11:35 PM
STL 71 C3's Avatar
STL 71 C3
^^ Good info.
Any working on mine will be real confused...lol I installed mine where you turn each in opposite direction...while looking at the outer tie rod on both sides I turn clockwise the make them shorter.
To Tie rod question
