77 headlight adjustment
Old Jan 17, 2012 | 07:34 PM
Milo3156's Avatar
Milo3156
Cruising
Default 77 headlight adjustment
The right headlight would not lock into place when up, I adjusted the swing bracket so it now locks. Now it is half an inch or more above the other light. How do I adjust the housing to match?
Old Jan 18, 2012 | 06:00 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
look in your AIM and you will see there is a screw adjustment to position the assembly relative to the body shell.
