C3 Question
Old Jan 17, 2012 | 08:11 PM
dajokster's Avatar
dajokster
Cruising
Default C3 Question
Hey guys I need to know if u can use parts from a 1980 in a 1978 for example can I use 1980 doors,interior ect on a 1978 or vis versa also is a 1978 a stingray ??
Old Jan 17, 2012 | 10:06 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Get the Parts interchange catalog. That will tell you what pieces can be swapped between years.
Old Jan 17, 2012 | 10:07 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Yes.. the doors, door panels, interior trim items are all the same with the exception of the pillar post... The 80-82 post I believe are shorter.... but just a tad. The dash pad is the same, the seat covers, rear roof panels... The only other main issue you'll find is the carpet set is different and the rear section can not be used on a 1978-1979 car.
Willcox
Old Jan 18, 2012 | 01:21 AM
dajokster's Avatar
dajokster
Cruising
Willcox
So the cassis are the same ??
Old Jan 18, 2012 | 03:37 AM
jesse10886's Avatar
jesse10886
no a 78,79,80,81,82 is not a stingray i can't remember for sure but i think 73/74 was the last year that they recieved the stingray badges on the body
Old Jan 18, 2012 | 04:32 AM
Bills17n72's Avatar
Bills17n72
76 was the last year of the stingray!!!!
Old Jan 18, 2012 | 07:57 AM
HeavyMetalHawk's Avatar
HeavyMetalHawk
I thought it was 75 the last stingray.... The good thing of the 1980 doors is that are a little lighter than previous models
Old Jan 18, 2012 | 08:03 AM
Jclgodale3's Avatar
Jclgodale3
Old Jan 18, 2012 | 10:34 AM
gbvette62's Avatar
gbvette62
An 80-82 chassis will work under a 78-79, but there are differences to them. The biggest difference being the rear end.
The 78-79 rear mounts to a crossmember, that's bolted to the frame. The 80-82 rear end has the crossmember, as part of the rear end, eliminating the need for the separate crossmember. The 78-79 rear end crossmember, will not attach to an 80-82 rear, without a lot of modification to the frame.
The trans crossmember is also different, but unless your using a dual exhaust system, the 80-82 trans crossmember will work just find.
The 78-82 pillar posts are all interchangeable too. It's the 77 posts that are different. All 78-82 right hand moldings, carried the same part number. The part number changed in 82, for the left side molding, but I think the difference had something to do with the opening for the VIN plate, not the overall length of the molding.
The 77's look like the 78-82's, but are slightly longer and shaped differently at the bottom, to meet the older style dash.
Old Jan 18, 2012 | 11:07 AM
dajokster's Avatar
dajokster
Cruising
Thank you thats what I needed to know.
Old Jan 18, 2012 | 12:13 PM
0Willcox Corvette
Former Vendor
I wanted to know where the changes were so today I pulled down some old originals and the AIM's.
The 77 was the odd man out cut different on the bottom. The 1978-1982 right hand was the same, the 1978-1980 left was the same, and the 1981-1982 are the same as the 1978-1980 with the exception of a very much larger opening cut for the s/n.
14011807 LH 466700 RH 81-82
466699 LH 466700 RH 78-82
Old Jan 18, 2012 | 08:08 PM
Ret.Horsecop13's Avatar
Ret.Horsecop13
St. Jude Donor '11-'12-'13-'14
To C3 Question
