Changed plugs and now running like CRAP
Old Jan 18, 2012 | 03:32 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Default Changed plugs and now running like CRAP
OK so I just did a tune up, new oil, filter,air filter,and now its running like its on 7 cyl...... WTF.....I checked all the wires to make sure they are on all the way ? ?
Could my timing be that off ? what am i missing ?
Old Jan 18, 2012 | 03:44 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Did you cross a couple of the plug wires?
Old Jan 18, 2012 | 03:45 PM
fanmanbd's Avatar
fanmanbd
Did you gap the plugs for the type of ignition you are running? Maybe the firing order?
Old Jan 18, 2012 | 03:49 PM
ptroxx's Avatar
ptroxx
I did one plug at a time.. so I dont think I could mix wires, I checked the gap on them all..car has been running fine till now....BANG HEAD.....
Old Jan 18, 2012 | 04:22 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
the boot may be over the plug but that doesn't mean its clipped into the plug. do you have a IR gun. if so while the car is running check each exhaust port. that will be a quick way to tell what one it is
Old Jan 18, 2012 | 04:23 PM
Hardway's Avatar
Hardway
Look at your car in the dark with the engine running. I experienced the same thing on an old Chevy truck several years ago. I tried everything and it was not until I was looking at it early in the morning before the sun came up that I saw the new plugs were arcing to the exhaust manifold. Turned out I had 2 plugs with cracks in the white ceramic. I pulled them out and put in 2 plugs from my Camaro at the time and it purred like a cat.
Go ahead and double check your plug wires again to ensure they are in their correct position on the distributor. Also, make sure the wires are firmly secured to the spark plugs. If they are not pushed on all the way they will not work.
Old Jan 18, 2012 | 04:25 PM
pauldana's Avatar
pauldana
Hey buddy..... Got to get ready for the 28th!!!!!! Had this happen to me on the on the jeep.... Bad msd plug wire.... Ohmed out ok on the meter, but when I did a plug wire pull while engine running, I found the wire bad..... Replaced it and all ok..... It was a factory crimp that was bad
Old Jan 18, 2012 | 04:26 PM
PRNDL's Avatar
PRNDL
Same thing happened to me. If you search i am sure we can find my similarly titled thread. In my case it was a bad spark plug wire. Of course, your experience may vary. In fact, I think the metal contact piece actually fell out of one of the boots, so the spark plug wire went on fine but there was no metal to metal contact. doh!
previous issues following tuneup: Car wouldn't start at all! One time it was bad points right out of the box. Another time, removal of the new distributor cap revealed.... missing rotor! ah! so many ways to screw it up!!!
Old Jan 18, 2012 | 04:58 PM
Marlin's Avatar
Marlin
Yep check the plug wires to make sure its not bad (broken connection, bad connector, etc...)
After that remove each plug and make sure 1 did not crack going in. Seen that before.
Old Jan 18, 2012 | 05:16 PM
BarryK's Avatar
BarryK
you can try pulling off the ignition wires one at a time and see if pulling one DOESN"T make any difference and you found which cylinder is the issue, than you only have to search a bit more to find out if it's a bad plug, a bad ignition wire, or bad contact on the distributor cap, etc
I had done a similar tjhing a few years back on my '65 and shotgun changed out all the wires, plugs, new dist. cap and rotor, etc.
Had car only running on 7 cylinders so had to go thru th whole process to find where the problem was. turned out to be TWO bad ignition wires from the brand new set I had just bought and installed.
Now i tend to just try to change out one part at a time to avoid the same type of disaster and nightmare of diagnosis
Old Jan 18, 2012 | 05:47 PM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
one of your "new" plugs is bad.
While the car is running,pull each spark plug wire off, one at a time, to find out which one is NOT making a difference. (you can do this at the distributor top to make it easy)
That would be the one thats faulty. wire, plug, fitting,etc.
Old Jan 18, 2012 | 07:04 PM
ptroxx's Avatar
ptroxx
FOund it.... broken plug....off to the parts house...
Old Jan 19, 2012 | 01:16 PM
Hardway's Avatar
Hardway
Glad to hear you found the problem. Is she running good now? I now keep a few spare plugs and wires around that I know work just for these types of situations.
Old Jan 19, 2012 | 09:08 PM
ptroxx's Avatar
ptroxx
Just ran it in the garage and sonds good.. we have rain now for a few days but as soon as it clears ill take it out....
Old Jan 20, 2012 | 10:52 PM
Sunstroked's Avatar
Sunstroked
I second that. Many moons ago I put an msd 6a into my 73 Camaro, it was a blue printed hipo that ran strong. I finished up the installation and drove it to the drag strip. It fell on its face any time it got over 4 k rpm. Popping and sputtering, although it idled ok. It wasn't until dark when I opened the hood and saw a laser light show emitting from the plug wires. New blue max wires and careful routing solved the problem.
To Changed plugs and now running like CRAP
