70 LS5 restamp or real?
Old Jan 25, 2012 | 02:07 PM
mainline666's Avatar
mainline666
Cruising
Default 70 LS5 restamp or real?
I know, yet another engine stamp thread. Please don't flame me to death.
Here's a few not-so-great pics of a 1970 LS5 I'm considering. Thoughts on the stamp?
[IMG][/IMG]
[IMG][/IMG]
Thanks.
Old Jan 25, 2012 | 02:39 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
70 was a screwy model year. The VIN derivitive in your pick is the correct format.
I'm no expert, but the stamps look okay to me.
Old Jan 25, 2012 | 04:44 PM
longbros's Avatar
longbros
I am no expert either, but it looks good to me. By the way, if you don't buy the car, would post details so someone else here might have a shot at it.
jr9170's Avatar
jr9170
From: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
Not great pics,but looks good.
Old Jan 25, 2012 | 05:53 PM
cmhidinger's Avatar
cmhidinger
If it's any consolation, my numbers (1970 LS5 here as well) look very similar to yours in that all the letters and numbers look deeply stamped except for the number "9" which looks like it barely shows up. Could be coincidence, could be that "re-stampers" are really that good. I don't know, just a thought.
Chad
Old Jan 25, 2012 | 07:31 PM
oldsarge's Avatar
oldsarge
I am with all those guys as well, looks ok. Does not appear to have been redecked or modified at all.
Old Jan 25, 2012 | 08:14 PM
SunsetC6's Avatar
SunsetC6
With all the pads I have seen over the years.
REAL DEAL
Old Jan 25, 2012 | 11:07 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
From what I can see, it LQQS like the real deal to me..........
Old Jan 26, 2012 | 08:21 AM
garage-ghost's Avatar
garage-ghost
I stayed at Holiday Inn last night and it looks good to me.
Old Jan 26, 2012 | 10:07 AM
Mike Ward's Avatar
Mike Ward
It looks good enough to me that I'd now pay a professional to inspect it in person, as well as the rest of the car. Average to good restamps are hard to pick out in pictures.
Old Jan 26, 2012 | 03:31 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
Comments:
1. The font, size, and location of the stamps look correct to me.
2. The surface of the pad looks relatively smooth. This is not necessarily bad, as it would be relatively smooth if the knives in the broaching machine had been recently changed. I don't see any swirl marks, which would be typical of a block that had been decked at the local machine shop. This is all good.
3. In the first picture, it looks like there are some marks going from top to bottom. The second picture is less clear, and looks like there could be some side to side marks. This is why an in-person inspection is needed, it's hard to tell the exact texture of the pad from pictures.
4. What transmission is in the car? The "CZU" suffix indicated a 4 spd transmission. Given how the VIN derivative stamp looks, light 9, relatively heavy 7 at the beginning and 5 at the end, it will really help if the car still has its original transmission. The VIN derivative stamp on the block and the trans used the same gang stamp, so alignment anomolies should be consistent between the two. Keep in mind that the stamp on the trans will probably be deeper and look a little different due to the metal being different, but you should still be able to detect those anomolies.
Old Jan 26, 2012 | 03:58 PM
BOSTONCAMARO's Avatar
BOSTONCAMARO
I have seen fakes and some good fakes at that...it is tough to reproduce the facing of the metal, that being said, I am with everyone else, that looks like the real deal, not been modified!
Old Jan 27, 2012 | 07:23 AM
72ls5fla's Avatar
72ls5fla
The font and broach marks look right IMHO.
Without putin the old broach-buster to it, you can't be 1000% sure.
Old Jan 27, 2012 | 12:15 PM
joewill's Avatar
joewill
given the rarity of a '70 LS5 convertible 4 speed ( maybe around 1300), there is very high motivation to fake it.
go into the transaction skeptical. few '70 LS5's have their original engine as they were run hard and blown up early in their life.
look for condition of the car. the rarity of this car would warrant one to take a specialist along with you to inspect it.
that car is just a couple of days older than mine...
now for the bad news.. that car is in the c3 registry with a picture of the block casting date of dec 18, 1969. that block is too old. it should have been cast in early march 1970... do not pay original engine money for this car. there was a work stoppage in the spring of '70 which would explain the nearly 2 months from the engine build to the car build date. but a block cast date 3 months earlier is just too much.
looks like a project.. convertible with a luggage rack, but the dates don't line up.
run forrest run...
Old Jan 27, 2012 | 03:12 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
run forrest run...
not speaking about this car, but is 3 months out of line for this year at this time or for any year?
I have a one owner, never been out of the car, needs a restoration 69 with a block cast the end of April of 69. Engine build date on the pad is 7/22 and build date for the car is 8/09. In this case, there was a strike in the Spring of 69...also, a change over to the 010 block.
Are you saying that there is no way this could be the correct block simply because of the 3 month cast date lag?
Having said all that, I have been following this post. My initial thought from looking at the pictures were the stampings appeared too crisp, deep, and new to me. My initial thought was restamp. I could change that if seen in person, maybe it's just the picture.
Old Jan 27, 2012 | 03:47 PM
joewill's Avatar
joewill
the corvette ***** out here know exactly what the date spread should be for all cars given specific strikes, work stopages, inventory stockpiles, transportation woes, etc...
I can't begin to make absolute statements regarding what they know. But I do know that I would not pay original engine money for a car with a 5+ month old engine in it. it would just come back to bite me when I tried to sell to someone in the future with the same concerns. Johns example above of a 3 1/2 month old engine is easier to convince me, but not 5 months.
everybody looks at the stamps, and hardly anyone looks at the casting dates.
if one is paying original engine money for a car, he needs to look at many many things and not just the stamp. tach redline, sway bar thickness, spring rate, emission stickers, u joint caps, radiator support, the rest of the drive train, just to name a few.
not saying for sure it is not original, but I would not buy it on that premise.
but hey.. it is a 70 bb 4 speed convertible. I sold almost the same car 4 years ago in much worse shape ( rusted out basket case NOM) for 15K. people start to drool and their eyes glaze over when they see a BB convertible.
Old Jan 27, 2012 | 05:41 PM
forman's Avatar
forman
Default real thats my vote
thats a real stamp
To 70 LS5 restamp or real?
Old Jan 27, 2012 | 05:42 PM
Mike Ward's Avatar
Mike Ward
I think you already made some absolute statements, and bold ones at that.
Could you give me the names or email addresses of these so-called n*zis that know everything?
Old Jan 29, 2012 | 10:58 AM
mainline666
Cruising
Default good catch
run forrest run...
Thanks for pointing out the discrepency between the block casting date "L 16 9" and the car's build date which is early May, e.g., VIN ...09755. FYI the stamp on the trans looks identical to the engine including the faded "9".
Is there any chance this is the right motor for the car, or is there simply NO WAY a motor casted in mid-December is going to end up in a car built in May?
BTW, the car as gone through a full restoration since those pics were posted on the C3 registry. Asking price is $42k. I guess that would be a very good price for a newer than new 1970 LS5 convertible?
Old Jan 29, 2012 | 11:13 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by mainline666
...Is there any chance this is the right motor for the car...
Yes.
...or is there simply NO WAY a motor casted in mid-December is going to end up in a car built in May?...
Never say never. The December casting date and May build date still meet the NCRS six month rule.
I agree with Mike. There is enough here to have an expert look the car over prior to purchase.
