Cold air induction on a 82?
Old Feb 3, 2012 | 06:49 PM
alconk's Avatar
alconk
Default Cold air induction on a 82?
Ok I'm trying to figure out why my flapper door is not opening?? I know it works because if you jumper the ADAL plug the door opens but under full throttle it does not. I looked in the AIM manual and it shows a relay mounted right next to the Map sensor but on my car it's not there nor the plug from the harness.. So could it be mounted somewhere else? I have looked and don't see one. I would really like to know where it gets it's signal to open it like maybe the TPS sensor?? I know on the 80-81 Z28s there was a switch under the gas pedal and as it made contact with it it opened the scoop but the Vette isn't that way??
Old Feb 4, 2012 | 10:39 AM
terry82's Avatar
terry82
my relay is on the fire wall next to the map sensor.most take off the flapper and let in cold air all the time .
Old Feb 4, 2012 | 01:40 PM
alconk's Avatar
alconk
Well I looked again and there is a relay next to the map but it's on the passenger side. The AIM shows it on the drivers side. Is it that??
Old Feb 4, 2012 | 07:47 PM
terry82's Avatar
terry82
could be,,,,,, trace the wires.
To Cold air induction on a 82?
