68-69 hardtop question
Old Feb 6, 2012 | 03:20 PM
Greatsteaks's Avatar
Greatsteaks
Default 68-69 hardtop question
I have a vynal hardtop with only two mounting bolt holes and no evidence of the third middle bracket being removed, also my wife found a "cv" date code on the rear window that should be November 69. I have read that only the 68 and early 69 came without the third mounting bolt but November 69 is a little late in the year. Are the two bolt hardtops sought out? Is there any extra value to them? We are thinking about selling it as it doesn't look like it was the original that came with our car. Also, did all the vert deck lids come with the middle bolt hole in them regardless if the car came with a hardtop or not? Our deck lid has the hole but our hard top does not. Thanks
Old Feb 6, 2012 | 03:35 PM
Lupigiato's Avatar
Lupigiato
I have a 68 and do not have a center lockdown latch on my deck lid (build date Oct 67). If you are thinking of selling it, I might be interested in buying it.
Old Feb 6, 2012 | 03:45 PM
Mashman's Avatar
Mashman
No, only cars that were optioned with a hardtop had the middle hole in the decklid.
Old Feb 6, 2012 | 03:46 PM
Greatsteaks
On these hardtops, do they have two clip in bolts that go into the latch holes or bolts with a washer and nut? Mine has none, my soft top has threaded bolts on both sides and I know they are not suppose to be like that (just received the correct ones today). I have read that the hard tops bolt in through the latch holes, if that is correct how do you put the washers and nuts on with the soft top under it? I'm guessing that they don't bolt in and what I read was wrong.
Old Feb 6, 2012 | 03:49 PM
Greatsteaks
Thanks, these things are a riddle, deck lid with three holes, hardtop from late 69 with only two? A lot can happen to a car in 40 years, lol.
Old Feb 6, 2012 | 03:58 PM
71 Green 454's Avatar
71 Green 454
I think the hardtop on my '71 is a '68 or '69. It has the center threaded bolt and 2 threaded studs w/ washers and nuts that go through the latch holes. It's a pain to install/remove.
Here's how I remove mine.....I release the 3 front latches, then release the deck lid and raise the top to remove the 3 nuts and washers. Then I lower the top back down making sure the deck lid closes shut, then I remove the 2 side bolts. Now the hard top should be free to raise up and remove.
Old Feb 6, 2012 | 04:03 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Purchase the assembly instruction manual (AIM). The AIM shows the factory installation of the optional hardtop and will also show whether the center thumb screw was used or not. Early cars did not have it; later cars do.
It also shows the rear studs on the hardtop and the nuts and spacers used on the underside of the decklid.
My April built 68 does not have the thumb screw.
Old Feb 6, 2012 | 04:08 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
Hi,
I am not sure what year the center mount was added, however 68 and (I think) 69 hardtops did not have the center mount. I am not sure when it was added but it is definitly a later production if the center mount is present. So, all tops specific to a particular build either had them or did not.
Not sure what year car you have however my guess is that top was built either for a real late 69 or early 1970 car.
Hope that helps.
Old Feb 6, 2012 | 05:00 PM
Roughrider's Avatar
Roughrider
I have a February '69 convertible and it does not have the center hole. I understand that later '69s do. Supposedly the additional mounting bolt was to better seal the top from water.
When I purchased a hardtop for my car it had the three bolts. It was a simple job to drill out the rivets for the center bolt bracket.
Old Feb 6, 2012 | 05:51 PM
Mashman's Avatar
Mashman
You can replace the two corner bolts with the softtop type pins that release - it makes it a lot easier to put the hardtop on, and off. With the softtop pins the only nut I have to worry about it the center one. With all of the other connection points on, the decklid can be released with the hardtop on, then the center bolt's washer, and nut can easily be put on/off.
Old Feb 6, 2012 | 06:33 PM
John 65's Avatar
John 65
October 67 here also. No center latch.
Old Feb 6, 2012 | 07:17 PM
Greatsteaks
There is absolutely no way I can reach those bolts with the soft top folded under the deck lid. Question: did verts come with shoulder strap belts? I have rear mouldings made for shoulder belts to roll up into but no shoulder belt. I thought the shoulder belts were taken out, maybe I have the wrong mouldings? The shoulder belt part of the moulding is what is blocking access to the bolts I think.
Old Feb 6, 2012 | 07:32 PM
Roughrider's Avatar
Roughrider
If I'm wrong I hope someone corrects me, but I believe convertibles began being equipped with shoulder harnesses beginning about March of '69. I remember reading that because my car was assembled on Feb. 20 and it only has lap belts.
Old Feb 6, 2012 | 07:35 PM
Greatsteaks
Are you guys with hardtops taking the soft top out when you put the hardtop on?
Old Feb 6, 2012 | 08:54 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Shoulder belts for convertibles in 69 were still an option, standard for the coupes. IIRC there were only about 300 so equipted convertibles ordered in 69.
As for the rear quarter trim the 68-69 was different than the 70 and later, it was narrow at the bottom and widened at the top to cover the top mechanism. That said, both styles cover about the same area of the folded top.
When I put the hard top on my car, I set the top on the car, latch the 3 front latches, insert the two bolts in the edge of the rear deck just behind the seats. Tighten those two bolts, unlatch the 3 front latches, unlatch the rear deck, raise the hard top and prop it up with something, this will get enough room to get under the deck to install the nuts and washers on the studs thru the deck. ( yes that is the correct way) The next time I install the hard top on my car, I plan on trying the soft top pins as suggested above.
By the way, I leave the soft top in place.
Old Feb 6, 2012 | 09:08 PM
bkvette3's Avatar
bkvette3
Same as John 65 - No center latch - Nov. 1967 build date.
Old Feb 6, 2012 | 09:12 PM
Greatsteaks
Ok. I'll have to try that. When you lower the top does the deck lid lock in place again easily?
To 68-69 hardtop question
Old Feb 6, 2012 | 09:15 PM
bkvette3's Avatar
bkvette3
No - soft top is folded down.
LemansBlue68's Avatar
LemansBlue68
I throw a towel in between the deck lid and and soft top as well as one between the rear window folds to protect the top and keep the window from getting scratched up while it's down.
No need to remove the soft top to install the hard top. It's a real PITA getting the soft top lined back up again if you ever have to remove it for any reason.
Old Feb 6, 2012 | 09:38 PM
c69vete's Avatar
c69vete
St. Jude Donor '07
Mine does.
