77 headlights
Old Feb 8, 2012 | 06:56 PM
Milo3156's Avatar
Milo3156
Cruising
Default 77 headlights
i have been working on the headlights that dont raise or lower. the right light housing when i raise manually it locks into place, the left opens and stays but does not lock into place. i adjusted the bolt on the stopper and it locks now but now has a .5" gap between the bottom of ligght housing and fron clip. how do i adjust this housing to match the other and lock into place?
Old Feb 8, 2012 | 09:18 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
if you look at your AIM you'll find the screw that adjusts the foot alignment to the nose section. it is best to adjust it with the lights closed from the bottom (through the grill opening works best in my opinion .
Old Feb 8, 2012 | 09:22 PM
Milo3156's Avatar
Milo3156
Cruising
What is the AIM?
Old Feb 9, 2012 | 03:35 PM
wan2run's Avatar
wan2run
Assembly Instruction Manual. Get one from just about any vendor here for your year. Definitely a necessity.
To 77 headlights
