washer pump issue
Old Feb 8, 2012 | 09:39 PM
Green73's Avatar
Green73
Default washer pump issue
hey folks,
I bought a rebuilt wiper motor with a washer pump. The pump will not activate with the switch. I ran a test light across the terminals and it lights when the switch is pushed. I took the cover off and if I lift the arm near the solenoid, the pump activates. Is there some adjustment that can be made for this?
Old Feb 9, 2012 | 12:07 PM
MelWff's Avatar
MelWff
when you push the switch, does the electomagnet which pulls the arm become energized? The coil could have a break in it.
