runout correction
Old Feb 10, 2012 | 07:26 PM
STL 71 C3's Avatar
STL 71 C3
Default runout correction
What is everyone using to correct runout on rotors?
Old Feb 10, 2012 | 07:39 PM
Mark Riles's Avatar
Mark Riles
Very thin copper sheet stock can be bought at chain hardware stores. Use a punch to cut out your shims. I used to use leather hole punches and a large hammer. Don't try drilling through it as it'll wrinkle up every time.
Old Feb 10, 2012 | 07:46 PM
rogman16's Avatar
rogman16
I cut out some old coke cans with scissors...
Rogman
Old Feb 10, 2012 | 07:55 PM
STL 71 C3's Avatar
STL 71 C3
Rogman
I thought about that but was worried about creating a gap under the rotor....I have right at .010 to correct...
Old Feb 10, 2012 | 07:57 PM
STL 71 C3's Avatar
STL 71 C3
interesting...I might look into this,
thanks both of ya
Old Feb 10, 2012 | 08:11 PM
Mooser's Avatar
Mooser
I've used everything from pop-cans, tinfoil, to proper brass or stainless steel shim stock.
There are some companies that make rotor shims, they are the correct size and have the stud holes punched in. They come in kits and are tapered. Lets say from .010 to .020, that would give you the .010 taper.
You measure the runout, mark the high spot and select the right one and put it in. Maintains full rotor contact since it's tapered and not just pads here and there.
Only used them once, buddy of mine worked at a place that had the kit so he got me the ones I needed.
I think they where Mitee or Mighty or something like that.
Now I just use pads around the studs, if you need .010" at one stud, try adding about .006" at the studs on each side. so it's not a total bridge across the spindle face/rotor
Mooser
EDIT
Found a link to P/N BA80309, Raybestos makes them, .003, .006 and .009 tapers. Look expensive, glad I got mine free when i did, shim stock looking better all the time
Old Feb 10, 2012 | 09:31 PM
markids77's Avatar
markids77
Icehouse cans make good shim stock, and the contents make good project lubricant.
Old Feb 10, 2012 | 10:31 PM
Mooser's Avatar
Mooser
Very thin copper sheet stock...... Don't try drilling through it as it'll wrinkle up every time.
If you need to drill it, try clamping it tightly between two pieces of flat wood (3/4" plywood or a couple of pieces of hardwood type (laminate, etc) flooring) and then drill through the sandwich, works well if you don't have large enough punches
Old Feb 11, 2012 | 12:03 AM
Retro78's Avatar
Retro78
Metal duct tape. I made a cardboard template so that it goes nicely over studs. Easy, cheap...no drilling needed
To runout correction
