77 Oil Pan Help
Old Feb 11, 2012 | 09:41 PM
codeman1330's Avatar
codeman1330
8th Gear
Default 77 Oil Pan Help
My 77 is in the shop and the mechanic has found a hole in the pan and decided it needs replaced. He has tried a few different pans and couldn't find one that fits correctly, so i ordered one from ecklers that claimed it would fit, and it doesn't fit either. He says that all the oil pans he has tried are for the wrong side. Like my car has the dipstick on the left side and the oil pans are meant for dipsticks on the right. (The left/right might be switched, can't remember which one he said) But my engine is a 350 and the original and believe it is an early 77. What could be the problem? Did they make varying oil pans for 77's?? Advice please!!
Thanks for reading!
Old Feb 11, 2012 | 10:15 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
IS this an original motor ? ? my dipstick is on the wrong side too.. but in have a ZZ4 crate motor..
Old Feb 11, 2012 | 10:31 PM
codeman1330
8th Gear
Yup, with matching numbers........ What Oil pan do you have in yours??
Old Feb 11, 2012 | 10:47 PM
noonie's Avatar
noonie
A 77 pan should have the dipstick bump on the driver's side. Pans are available for either side.
Cheapest way is to just weld the hole shut. Good welder can make it not noticeable.
Old Feb 12, 2012 | 02:58 PM
C3bdj1's Avatar
C3bdj1
St. Jude Donor '10
My '77 is a numbers matching/original motor (late).
Dipstick on the left (drivers) side.
Can't see it...but it's there, just below the oil fill cap.
Bobby
Old Feb 12, 2012 | 03:10 PM
mikep3's Avatar
mikep3
Bobby, Nice engine bay, very nice.
My 78 needed a new oil pan as the old one was bent and dented. Replaced with a Moroso 20170, no leaks with a one piece oil pan seal.
http://www.jegs.com/i/Moroso/710/20170/10002/-1
Last edited by mikep3; Feb 12, 2012 at 03:17 PM. Reason: forgot oil pan part number
Old Feb 12, 2012 | 03:24 PM
C3bdj1's Avatar
C3bdj1
St. Jude Donor '10
Thanks Mike.
I did the clean & paint detail in 2010 with the engine in the car. Took about 2 weeks of nights and weekends.
My back has not gotten over it yet!
Bobby
To 77 Oil Pan Help
