Collapsing Lifters To Restart Engine?
Old Feb 15, 2012 | 12:36 AM
Kim72's Avatar
Kim72
Default Collapsing Lifters To Restart Engine?
An old time mechanic, of a friend of mine, tells us that all the existing lifters on an engine, that has not been started for a long time, should be removed and collapsed before trying to restart. He claims, otherwise, we will have trouble starting the engine. While l'm no expert, l've been around cars/engines for a long time and have never heard of this. Am I missing something here? Is this the case?
Old Feb 15, 2012 | 12:59 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
How can we "collapse" a lifter? did he mean to pump or prime it with oil first?
Old Feb 15, 2012 | 01:09 AM
tracdogg2's Avatar
tracdogg2
That is just nonsense.
Old Feb 15, 2012 | 08:16 AM
Indiancreek's Avatar
Indiancreek
I wonder if he's talking about making the push rod cup move in case it's stuck where it's been for some time?
Old Feb 15, 2012 | 08:44 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
How old is your "old time mechanic"?
Old Feb 15, 2012 | 10:20 AM
69 Chevy's Avatar
69 Chevy
Old Feb 15, 2012 | 10:35 AM
427basketcase's Avatar
427basketcase
Yea, he is probably right, then after that you go to the front of the car, grab the crank and start turning it to start the engine
Old Feb 16, 2012 | 11:04 AM
tracdogg2's Avatar
tracdogg2
Trying to start an engine with collapsed lifters is much harder to do and have a good chance of spitting off a rocker arm. I think he is thinking about the lifters holding the valves open which is impossible with an assembled engine.
Mike
To Collapsing Lifters To Restart Engine?
