68 Power Door Locks
Old Feb 18, 2012 | 12:43 PM
68vetteman's Avatar
68vetteman
Default 68 Power Door Locks
Has anybody ever heard of power door locks for a 68? I want to take my door panels off soon and if there is a kit I'll look into it. I have an alarm system that can activate them. Thanks
68 Vetteman
Old Feb 18, 2012 | 02:45 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
buy a set of generic door locks, and tie them into your alarm system you will need 2 - 12v relays to make everything work.
Old Feb 18, 2012 | 04:10 PM
68vetteman's Avatar
68vetteman
Thanks for the picture 69 Vett!! That helps a lot. I just took the driver side panel off and had no idea how or where a power door lock was installed.
68 Vetteman
Old Feb 18, 2012 | 04:17 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I did this about 8 years ago, and the actuators have never had an issue operating the mechanism. I used the door lock/unlock outputs of the aftermarket alarm to control them, but you can also buy stand alone remote keyless entry systems that do the same thing. I have posted this before, so I will quote myself from another post that I made years ago!
Originally Posted by 7t2vette
My system is controlled by an aftermarket alarm. The numbers on the wiring diagram inside the relays represents the terminal numbers on the relay. This wiring can be changed to operate any other way you like. My alarm operates the switches I have indicated attached to terminal 86 on both relays. Those "switches" are actually ground output signals from the alarm. If you don't have an alarm, or want to control the locks manually, you will need to install two switches, one for lock, one for unlock, with one side of the switch going to ground as shown in the diagram, and the other side going to terminal 86 of the appropriate relay(lock or unlock). This will operate BOTH doors at once. If you want individual control, then you will have to have a set of switches and relays for each door, for a total of 4 switches and 4 relays.
Electrically speaking, here is how it works: if you look at the diagram, you will see that in it's current state, both coils are open (have no ground input) and both sides of the actuators are grounded. The actuators move in one direction when + and - 12v are applied to the wires, and they move in the opposite direction when + and -12v are reversed. There is no set direction to install them, but you have to get the wiring right to make them move in the right direction when you want to lock or unlock the doors.
When either coil gets a ground signal on terminal 86, it causes the coil to move the internal switch from terminal 87A to terminal 87 which completes the circuit and sends +12v to one side of the actuators (which side depends on which relay coil you just energized). The other side of the actuators is still connected to ground via terminal 30,through the internal switch to terminal 87A ,which is grounded. The actuators move the opposite way when the other coil receives a ground signal on terminal 86.
The actuators can be bought at any good car stereo/alarm store or Ebay for under$10. The relays can be bought there too or at a car parts place (usually near the fog lights section) for around $5 each. This is an inexpensive project to do, and it is cool too! I prefer to use BOSCH relays for thier quality, I have had cheaper ones crap out on me before.
The physical install is easy too. The hardest part is getting the wires through the rubber conduit between the door and the body. If you look at the pic of my door, you will see where I decided to put the actuators. They fit perfectly behind the door skins here, and are parallel to the lock linkage. They are mounted on the removable cover, with a grommet for the wiring. The rod must be bent by you for proper operation. I drilled the hole in the linkage elbow to hook one end of the rod through it. The actuators come with "clips" that clamp onto the actuator rod and the lock linkage, but the linkage on Corvettes is too big a diameter for these "clips" to work. Bending the rods to work takes a little time, but use mine as guide for bending yours.
Here is how some other guys have done it, and if I had to do it again I would do it this way for a more linear travel of the actuator push rod:
Old Feb 18, 2012 | 05:59 PM
68vetteman's Avatar
68vetteman
Again thanks for the great pictures. It doesn't seem like that hard of a project.
68 Vetteman
Old Feb 18, 2012 | 06:38 PM
rebelee08's Avatar
rebelee08
Default Sorry to crash
Do you know if this same fix will work for my 79? My only problem is I believe the previous owner cut the wires :-(
Old Feb 18, 2012 | 10:00 PM
69Vett's Avatar
69Vett
electricity dose not care which year your car is,
this can be adapted to any vehicle, even Fords !
it works well with aftermarket alarms,
then you just use the remote key fob to activate.
Old Feb 18, 2012 | 11:06 PM
rebelee08's Avatar
rebelee08
Default Thanks!
Can I inquire as to why brand of alarm you used?
To 68 Power Door Locks
