Are the numbers molded into your hood? I would suggest posting a photo or two so we can see where they are and maybe someone could help you out that way.
Ontopic: If possible, post a picture on the numbers. Is the hood aftermarket? The numbers you are asking about could mean just about everything. Perhaps the numbers are used for alignment? No idea
hi can anybody help me i have under my hood at the top tow numbers 1 and a 4 can tell me what they mean.thanks
I suspect what OP means is that his hood on either side at the top, has yellow-grease markings in the form of numbers "1" and "4."
I saw this on VIN 900003 and those numbers were "2" and "5." I did not check at the time to confirm, but now suspect (after going back to the photos) it may have been a reference to striker shims at the top of the hood. I have those photos if OP is not able to post. This has been the only time I've seen these marks on a hood.
BTW, checking my 78, I've got 2 shims on one side and 5 on the other.
