wheel stud
Old Feb 22, 2012 | 09:54 PM
tarheeljww's Avatar
tarheeljww
Default wheel stud
evening,
I broke a wheel stud on a 71' and am looking for help.
I searched and found threads that explain that it is possible to drill a hole in the back plate to insert stud from behind, at the 9 oclock postion on drivers side and the 3 on passengers.........
damn if I can figure out how to get in there.
Can somebody please post a better description and maybe a picture or two???
Thx.
Old Feb 22, 2012 | 09:59 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
take BFH and take a good hit from the outside of the bad one if its broken off flush then take a center punch and hit it. then put the new one in the same fashion
Old Feb 22, 2012 | 10:11 PM
tarheeljww's Avatar
tarheeljww
Thanks......but I have no idea what you just said.......BFH??
I did cut the stud off and punch it through and was able to get the head to drop out the bottom between the Parking Brake shoes.......but have no idea how to drill a hole in backing plate to thread a new stud in from back as some have said is possible..
(BIG F**KING HAMMER ????)
Old Feb 22, 2012 | 10:37 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
I've done this......
Remove the parking brake adjuster.
Grind a small bevel on the head of the new stud, just enough to keep it from wanting to dig into the backing plate.
At the 6 o-clock position set it in place from the rear on an angle with the bevel against the backing plate. Give it a whack with a hammer, there's enough flex in the backing plate that the stud should snap in place.
Grease up a couple big washers and with a lug nut flat side in, pull it into place.
Old Feb 22, 2012 | 10:40 PM
Mooser's Avatar
Mooser
That's friggin hilarious !!!! 2" stud with about 1-3/4" space, you need to pull the spindle off the arm to change the stud
I've never looked at that before, finger tight lug-nutz for me from now on
I Just wrote a big post with tons of pictures showing why this isn't a great idea (drilling), then looked at the room neat the adjuster and thought it's possible to go there.
KapsAS is right on. I was gonna sugest cutting some of the shield in that area to clear the stud, you need about 2 inches for the stud.
Actual mileage may vary, results not typical, professional driver on closed course...
Mooser
Old Feb 22, 2012 | 10:47 PM
KapsSA's Avatar
KapsSA
HA HA
Don't let the other experts worry you, you're not grinding the head OFF, you're putting a bevel on it.
http://forums.corvetteforum.com/c3-t...placement.html
edit....sorry, thought you were giving ME ****!!
Old Feb 22, 2012 | 10:55 PM
Mooser's Avatar
Mooser
Originally Posted by KapsSA
HA HA
Oh no, I think you method is great, I'd only cut a notch in the shield to use the 2" stud, the 1-3/4 should pop right in like you say.
The studs are mostly loaded under shear and every one I've ever seen, seem to break at the weakest point, start of the thread (baring any flaw)
Old Feb 23, 2012 | 02:51 PM
tarheeljww's Avatar
tarheeljww
thanks for the input and especially the pictures.........
I might even be able to do this.
Is this a great forum or what????
Old Nov 30, 2012 | 07:40 PM
John92LT1's Avatar
John92LT1
Double-hitting with another post that I just made- how do you remove the parking brake adjustor? Mine appears to be frozen solid.
Old Dec 2, 2012 | 02:00 AM
my 76 ray's Avatar
my 76 ray
You should be able to pry the brake shoes apart and that will allow it to drop out. You should only need to move the shoes about a quarter inch to get it out.
To wheel stud
