Replacing antenna
Old Feb 25, 2012 | 08:37 AM
Wrecked82's Avatar
Wrecked82
Default Replacing antenna
Tired of having to replace the antenna every 5 years or so. Can I just unscrew the current mast and put another mast in place, leaving the motor, etc. as is?
Old Feb 25, 2012 | 09:32 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The problem is likely to be the cable which raises and lowers the antenna. You can get a repair kit.
Old Feb 25, 2012 | 04:18 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
if it is in fact a 'factory' antenna.
If you've replaced it every five years or so can't be sure what it is.
Some of the aftermarket ones are pretty cheap!
To Replacing antenna
