decode my block
Old Feb 26, 2012 | 12:57 PM
jay_c3's Avatar
jay_c3
Default decode my block
Hey guys my 75 vette has a gm replacement engine. I like to decode my block to see what extra information i can get from it. 1M10199WP. I know it was made in Mexico.
Old Feb 26, 2012 | 01:53 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
are you sure its a GM replacement block. that breaks down to a 1969 GM truck built at Lansing MI on Jan 19, 1969. it was a 350 Truck with 255HP RPO code LS-9 using a T-H 400 trany, with 4-Brl carb that was a 4-WD
Old Feb 26, 2012 | 03:27 PM
jay_c3's Avatar
jay_c3
The previous owner said it was a Gm Craite Motor that had only about 1k miles on in for what its worth. The valve covers say Gm Craite motor. When i started to decode it the first letter M says its from GM in Mexico. than after that i wasn't sure.
Old Feb 26, 2012 | 04:45 PM
scottyp99's Avatar
scottyp99
What's the actual casting number of the block?
Keep the shiny side up!
Scott
Old Feb 27, 2012 | 08:15 AM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
Isn't the second to last alphanumeric a "V" instead of a "W" in your first post?
Old Feb 27, 2012 | 10:27 AM
Mike Ward's Avatar
Mike Ward
As far as I know, there's no known method of decoding the stamp pads on GM crate motors.
Not sure where the info on it being a '69 truck came from, but the pic shows it being a 'square pad' which didn't appear until the late 70s at the earliest.
Old Feb 27, 2012 | 10:44 AM
69 Chevy's Avatar
69 Chevy
Most likely scenario, it is a CHINA made knockoff. They don't know how to spell crate either.
Old Feb 27, 2012 | 03:47 PM
Nowhere Man
I decode it from the info given before the picture. If I am wrong then it wont be the first time
Old Feb 27, 2012 | 03:56 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
....If I am wrong then it wont be the first time...
I'm not certain there is an engine assembly plant in Lansing. The BIG one is at Flint.
Old Feb 27, 2012 | 04:10 PM
Nowhere Man
I did A quick qoogle search on GM assembly plants for vins and found a chart showing "M" as Lansing.
Old Feb 27, 2012 | 04:43 PM
Mike Ward's Avatar
Mike Ward
1M is the prefix for the Made in Mexico GM crate engines. 1019 is probably an October 19th assembly date. 9VP has been seen on many crate engines. As mentioned before there's no confirmed knowledge of what that decodes to, other than some speculation that it's the 250HP gross/175HP net version.
To decode my block
