Main wiring harness
Old Feb 29, 2012 | 05:23 AM
edtekk's Avatar
edtekk
Default Main wiring harness
Does anyone make the spade style main wiring harness for a 1973 small block with manual trans. with a/c. that replaces the original style glass fuse block harness?
Old Feb 29, 2012 | 07:17 AM
Lupigiato's Avatar
Lupigiato
Lectric Limited is the foremost expert in reproduction harnesses that meet GM specs. I can't speak to the specific criteria you ask, but Id try LL first as you locate your replacement.
http://www.lectriclimited.com/. Let us know how you make out.
Old Feb 29, 2012 | 12:49 PM
Frogday's Avatar
Frogday
Painless makes this type of replacement wiring harness with the spade fuses. http://www.painlesswiring.com
To Main wiring harness
