82 emission questions??
Old Mar 2, 2012 | 07:50 PM
alconk's Avatar
alconk
Default 82 emission questions??
I have removed the air pump and EGR but have not started it yet, waiting on the EGR cover plate. Anyway will I get a check eng. light?? And if so I don't want to remove the buld but thought about installing a jumper wire in all the plugs I unplugged so it has a continunity. The air pump divertor, EGR solenoid and something else was unplugged.
Old Mar 2, 2012 | 09:02 PM
terry82's Avatar
terry82
you should not have a problem .the only part that goes to the ecm is the 02 sensor.
Old Mar 2, 2012 | 09:29 PM
alconk's Avatar
alconk
Outstanding! Already looks better under the hood without that stuff. What else would you reconmend?
Old Mar 3, 2012 | 12:16 AM
TexasMadMan's Avatar
TexasMadMan
I'd recommend you not throw what you took off away. You may need it someday. If not, you could probably sell it to someone that needs it for a good penny.
Old Mar 3, 2012 | 12:23 AM
alconk's Avatar
alconk
Yes I agree, already put it in a box for safe keeping including the hardware.
Old Mar 3, 2012 | 09:13 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by alconk
...What else would you reconmend?...
Putting it all back on if you have to pass emissions testing.
To 82 emission questions??
