Hello all, a quick question for the experts
Old Mar 3, 2012 | 10:04 PM
Tomahawg's Avatar
Tomahawg
6th Gear
Default Hello all, a quick question for the experts
Looking to get my first Vette.
I'm pondering an early year C3 in a big block. It looks like for 68 and 69 there were several big block options.
The question, is there any 1 motor I should stay away from due to reliabilty issues?
Also, I'm really interested in reliability with out alot of tinkering as I'm not wanting to spend much time under the hood.
Also I've noticed most big blocks were not optioned with AC, since I live in Houston, would adding a vintage air pose any problems mechanically speaking.
Any other advice you could provide on things to look out for would be welcome.
P.S. this would be just a weekend car with several trips during the year at up to 1000 miles round trip and i'm lookin to keep the cost under 30K
Thanks in advance.
Old Mar 3, 2012 | 10:45 PM
Tim H's Avatar
Tim H
Thanks in advance.
This whole question is answered with one answer. Mid 90s vette!!!
Old Mar 4, 2012 | 12:07 AM
BBCorv70's Avatar
BBCorv70
Thanks in advance.
Big blocks were available from 68 through 74 for C3s. I've seen many with A/C, not unusual. Vintage air should work fine as well.
I know of no reliability problems. Some of the higher performance versions may require more attention...
Old Mar 4, 2012 | 09:04 AM
C3 4ME's Avatar
C3 4ME
Yeah, you could get a factory big block w/ A/C, and I don't know of any problems specific to havinge A/C. The big blocks should be just as reliable as a small block, but a little harder to work on, especially w/ A/C, due to less room in the engine compartment. In your area, finding one w/ Vintage Air, or similar a similar aftermarket unit already added may not be too hard either.
Old Mar 4, 2012 | 09:43 AM
3JsVette's Avatar
3JsVette
Thanks in advance.
"reliability with out alot of tinkering"
"most big blocks were not optioned with AC, since I live in Houston, would adding a vintage air pose any problems "
"several trips during the year at up to 1000 miles round trip and i'm lookin to keep the cost under 30K"
Buy a C5 Z05 and it solves all those issues with about 5K left over for whatever future issues or improvements you chose.
Sorry but the truth be told a real nice big block with A/C even in this "depressed market" is going to chew up that budget if it meets all your criterior. Any big block car is going to be 40 years old and unless it has had a fresh frame off with everything rebuild it's going to need "tinkering". If it's "frame off completely restored numbers match" it's not going to be 30K. On top of that you can't expect a 40 year old stock A/C and cooling system to be as efficent as a C5.
I'm not trying to be negative or burst your bubble but hoping you will realize what is involved to meet your goals and budget as well.
Good luck in your search where ever it takes you.
Oh and in NO way am I an expert. That's just IMCO.
Old Mar 4, 2012 | 10:11 AM
Ironcross's Avatar
Ironcross
Default BB`s everywhere
all kinds of BB`s with air conditioning, its just not available with the high revving 4 bolt main solid lifter engines unless you make it yourself....Chevelles, Camaros, full sized Chevys and Corvettes....there all over the place......from 65-74......And don't be afraid to add air to HP engines ither....I added or used AC with L-88`s and never had any problems except finding the 100+ octane fuel that should be used with them.....
I forgot one element...buy a new or newer AC equipped Vette as suggested above and enjoy it...otherwise build or buy a C-3 BB trailer queen
Old Mar 4, 2012 | 10:22 AM
dar322's Avatar
dar322
St. Jude Donor '12-'13
repairs can really add up if you have to rely on a shop for repairs. just because they are the experts, they will charge $120 hr and a frame-off is $50k minimum. you may want to find a local expert forum member and avoid the shops for repairs, maintenance and upgrades.
Old Mar 4, 2012 | 10:45 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
No disrespect, but a nice 68 or 69 air conditioned big block will likely exceed your $30K budget.
Good reading here:
FWIW: if gasoline prices keep going up, you will want to take another look at a thousand mile cruise in a big block.
Good luck with the hunt.
Old Mar 4, 2012 | 11:04 AM
keithinspace's Avatar
keithinspace
I'm all for having the right person connect with the right car. But given all your criterion, I would politely offer that Kerbeck Corvette has a 2002 Z06 available with 8,732 miles for $29,990.
If I wanted "...reliability with out alot of tinkering...", "...AC, since I live in Houston" and were driving "...several trips during the year at up to 1000 miles round trip..." it'd be an absolute no-brainer.
A 1969 big-block Corvette would consume you.
Old Mar 4, 2012 | 02:34 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Welcome to the movies.
Does your $30k "cost" limit apply to the price of admission...or does it include as many trips as necessary to the concession stand? If you want a reliable '69 BB and are not interested in tinkering yourself, then you would be better off looking for a non-pedigreed car with a properly rebuilt replacement or crate engine...along with most everything else of a mechanical and electrical nature having already been dealt with correctly. Forget the documented original drivetrain route. If you start out being smitten with pretty new paint and interior...for $30k you will likely come up short in the reliability department. As far as those long trips go, real bikers have a saying "But the chrome don't get ya home."
BTW, I would consider myself an expert. I happen to have a PhD in '69 BB Restoration, having spent the last 8 years attending the University Of Laying On Your Back Under The Filthy Leaking Unrestored Car With Bloody Knuckles. I'm into mine $55k hard money and it appears to finally be reliable...I hope. At least I don't have an A/C system to worry about fixing. Another $15k for paint, chrome and interior...then it can finally win that $20 trophy at a local beauty contest! At least I saw one just like it sell at Kissimmee for $70k.
Old Mar 4, 2012 | 02:49 PM
CorvetteFirstTimer's Avatar
CorvetteFirstTimer
I'm not an expert, and don't mean to come across rude, but it seems that you dug yourself a small hole with all the criteria you want. Best thing is not to look for an all original car. If you can get past that, you should be good. Anything you buy will most likely need work. You can get a shop to maintain it, but it will be a lot cheaper just to do so yourself. I'm doing a top end engine rebuild right now for just over a thousand dollars. That includes all the parts and a little bit of labor that a friend is giving me a hand. If I were to bring it to a shop I'm looking way over 2 grand. Good luck in your hunt.
Old Mar 4, 2012 | 04:35 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
For 68 and 69 the 427/390 has a single carb which makes it a bit simpler than the tri-carb, 400/435 horse cars. AC was available with the 390 and 400 horse cars but would likely exceed your $30,000 if you want an original car. The 390 horse is a very civil big block that makes plenty of low end torque.
They are all old cars and you will need to tinker.
Old Mar 4, 2012 | 05:33 PM
69VetteFla's Avatar
69VetteFla
Old Mar 4, 2012 | 06:15 PM
Tomahawg's Avatar
Tomahawg
6th Gear
Thanks for the advice everyone
To Hello all, a quick question for the experts
