Lower Steering Column Cover
Old Mar 4, 2012 | 10:13 AM
javaman's Avatar
javaman
2025 C6 of the Year Finalist - Modified
2021 C6 of the Year Finalist - Modified
Default Lower Steering Column Cover
Over the years, previous owners of my car (69 standard steering column) were not careful with their ignition keys. As a result, the cover under the switch is badly scratched. Is this cover the "Lower Steering Column Cover"? If not, what is cover called and is it replaceable? Thanks as always.
Old Mar 4, 2012 | 10:43 AM
Clubby99's Avatar
Clubby99
Buy a new one (all vendors sell them) or paint over (with a dye) an original found on EBAY, this forum, etc.
Link:
http://www.ecklerscorvette.com/corve...1969-1977.html
Original may fit better.
Old Mar 4, 2012 | 10:50 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Sand out the scratches and repaint yours. Beats the heck out of trying to swap out one.
Old Mar 4, 2012 | 10:59 AM
javaman's Avatar
javaman
Thanks guys. Glad to know I was looking at the right part. I'm leaning towards re-painting. Two questions though....is the cover easy to remove or should I mask and paint it as it is? Is the original paint (dye??) available?
Old Mar 4, 2012 | 11:52 AM
Shark Racer's Avatar
Shark Racer
The lower steering column cover is underneath the column, connects the dash together underneath it. Unless people used a necklace as a key ring that's not the piece that would get damaged.
This is most likely what you're thinking about: http://willcoxcorvette.com/product_i...oducts_id=6953 (I realize this is for a later tilt C3, but I don't see a corresponding part for an early C3).
Old Mar 4, 2012 | 12:09 PM
javaman's Avatar
javaman
Me thinks you are correct. The damage is just under the switch where a large set of keys could swing and scratch. Gonna check more closely in just a bit.
Old Mar 4, 2012 | 01:45 PM
Clubby99's Avatar
Clubby99
3 screws. Can't be easier than that.
Old Mar 4, 2012 | 02:11 PM
mffi115's Avatar
mffi115
It's more involved than that. I just rebuilt a later C3 column and took apart my stock 73 column. If it can be sanded and painted w/o disassembly, do it. There's a lot more to getting that section off than 3 screws; remove turn signal collar, ignition switch, etc. Jim Shea has posts on the forum where you can down load instructions for C3 steering column disassembly, repair and assembly. Here's a link to Jim's info paper It's well worth the time to download and read before you make a decision what to do.
http://jimshea.corvettefaq.com/?p=909
Old Mar 4, 2012 | 02:39 PM
Shark Racer
I think he still thinks we're talking about the lower column cover...
Old Mar 4, 2012 | 06:18 PM
mffi115's Avatar
mffi115
This is what I'm talking about, Steering Column Lock Housing Cover.
Old Mar 4, 2012 | 06:53 PM
javaman's Avatar
javaman
So the plot thickens....don't have time tonight to look at Jim's post but will do so before ultimately deciding what road to take. Will keep everyone interested posted. Thanks!
Old Mar 4, 2012 | 07:51 PM
Shark Racer
Not you - clubby99 thought the conversation was still on the lower column cover.
@javaman - I would try to paint it on the column, myself. You can get a number of other pieces at the same time.
Old Mar 5, 2012 | 08:55 AM
mffi115's Avatar
mffi115
Oh, sorry - I was sleepy and grumpy.
I agree, unless you feel like getting intimate with the guts of your steering column. If you do, I would suggest getting the special tool to compress the retaining plate spring to remove the c-clip. It's a real bear w/o one. How do I know? - sore thumbs and an upset wife because I made her help me in a cold garage.
To Lower Steering Column Cover
